Read this: Trading and advertising on the forum - Conditions and how to enquire
Number 23 Boosted Time.
#761
Posted 26 February 2021 - 05:41 PM
Soz. Feel bad now.
#762
Posted 26 February 2021 - 10:56 PM
No worries. Any idea if it looked the same?
UKDM 1998 1.8 Mk2 Sport - Current mods- Custom 6 point chassis mounted front splitter and sideskirt extensions, battery cut off switch, OEM 'small skirts' and lip, HEL braided brake lines, OEM front upper strut brace with MC brace and mazdaspeed sticker, custom made 2" high flow catback exhaust, Japspeed 4-1 exhaust manifold, Lorber 15" alloys in fiat 750 maroon volcano, uniroyal rainsport2s, Ebay special JDMyo! gear knob, tinted indicators, colour coded reflectors, black headlight inserts, LED sidelights, SMD number plate bulbs, dimpled and grooved mtec brake discs, mintex brake pads, de-tango'd headlights, amber bulbs, RGB footwell lights, SMD interior light, Deltastyling spoiler, foamectomy seats, mazdaspeed seat belt pads, ring ultimax headlight bulbs, IL Motorsport style bar in custom paint, ford fan washer jets, Skidnation coolant reroute with Kia thermostat housing, Gates 22436 radiator hose with hose bracket, 82/85 degree twin valve thermostat, D1 spec engine bay dress bolts, stainless steel bolts throughout engine bay, EGR blanking kit, painted brake calipers, painted tow hooks front and rear, wrinkle painted cam cover, de-greened dials with white SMDs, red needles, painted cigarette lighter, painted oil filler cap, custom made cup holder, painted radiator retainers, polished slam panel, painted alternator, painted upper manifold, painted throttle body, painted header heat shield, painted relay bracket, painted loom brackets, painted diagnostics box bracket, painted wash fluid brackets, painted ABS brackets, painted airbox brackets, painted horns and brackets, painted throttle cable brackets, painted charcoal canister brackets and hard piping, painted wiper rods, painted engine hooks, painted clutch line bracket, Jass offset license plate bracket, offset square plate, 1lt foam fire extinguisher on custom bracket and custom Velcro retaining strap, POR15 rust proofed to within an inch of it's life, cavity waxed and fully seam sealed
UKDM 2001 mk2.5 - Current mods- SMD interior light, SMD number plate lights, Corbeau Sprint (yes it fits!), modified mk2.5 door card, Skidnation seat brackets, Corba 1046 remote central locking unit, Driftworks basics 350mm leather steering wheel, NRG short hub, NRG 2.5 quick release hub, 8" weighted gear knob, factory electric wing mirrors, factory electric aerial, Kage 4" exhaust with additional powerflow silencer, foam fire extinguisher, custom fire extinguisher mounting bracket, painted cam cover, painted oil filer cap, 15" Advan SA3Rs, Nankang NS-2R 180tw, offset plate bracket, RGB footwell lighting, sun strip, painted calipers and carriers, painted headlight inserts, softtop delete, brake fluid reservoir sock, GCR3 roll bar in custom gloss black, Corbeau Ultima Pro 2006SSU 6 point harness, push button bumper quick release pins, twin port oil catch can, engine bay respray, fully POR15 rust proofed chassis, full chassis seam seal, custom permanent hardtop side mounts, Jass permanent hardtop front mounts, M-tuned large rear rotor spacers with corresponding 276mm SVT brake discs, Freakyparts larger front rotor spacers with corresponding 11" Corado G60 front rotors, HEL braided brake lines, Byba Kits GV style front lip, SVT under chassis bracing, painted radiator brackets, mazdaspeed seat belt pads, charcoal canister delete, large Mazdaspeed side skirts, adapted NA short shifter, 60mm alloy radiator, 3" brake ducts, upper strut brace with MC brace, 3.9 type 2 torsen, 80A diff bushes, front tow hook, rear tow hook
2004 Celica T Sport - Current mods- Meister Zeta Pro coilovers, Forged Wilwood dynalite front calipers, Yellow stuff brake pads up front, Drimpled and slotted discs, Braided brake lines, TRD stubby aerial, Short shift kit, 17" alloys powdercoated in metallic granite, TRD centre caps, Invidia exhaust, Cusco brake master cylinder brace, SMD side light bulbs, butterfly valve delete, Aux to CD converter, 8" gear knob, sun strip, interior SMD bulb, remote damper adjusters, solid shifter bushes
#763
Posted 27 February 2021 - 08:21 AM
#764
Posted 27 February 2021 - 11:50 AM
Sent from my VOG-L09 using Tapatalk
#765
Posted 27 February 2021 - 12:51 PM
Plus id feel like i should have a paperbag on my head driving it.
My wife loves it however so happy days.
#766
Posted 27 February 2021 - 01:55 PM
Yeh a lad I know used to say that they were really quick but bloody awful to driveIts the wifes fk2 type r gt in met blue. It replaced the Mazda 3 mps. Ive only driven it a handful of times and handful sums it up..whilst it goes like the clappers it torque steers much like the mps..not for me.
#767
Posted 27 February 2021 - 02:25 PM
#768
Posted 27 February 2021 - 04:21 PM
#769
Posted 03 March 2021 - 04:39 PM
Quick little wiring job. Bought a red led so put that in drivers side reverse light.. was gonna use led light that came with car but as ive cut rear bumper up no logical place to plonk it...saves some weight too. Stuck a few stick on few days ago.
Defo got more jobs behind me than in front...lol...
Nearly finished woohoo.
#770
Posted 03 March 2021 - 04:42 PM
1. Mot it
2. Weld door bars in at my mates ( better welder).
3. Fog x inside windows..( buy it first).
4. Usb power supply for camera
5. Revist rear view mirrow..bit floppy.
#771
Posted 04 March 2021 - 08:15 AM
Look tobe about 3mm all round so ive snapped them up. High end tyre looking forward to seeing how they compare to ar1.
My jr12 wheel set up is forsale on facebook..its just too wide. ( with the spacers).
Few bits for sale.
15x8.5 j et13 with 225 45 15 ar1s. 2.2mm tread. £500. New last year. 1 mark on 1 wheel 10mm on rim caught on trailer.
Just want wheels. £300. Pick up only or sort your own courier.
Firefly classic sideskirts brand new. Just offered up on car. Not using as believe will beach on trailer. £70. PICK UP only.
270mm front brake kit. New calipers and hel lines in blue.
New sliders and used carriers. Brand new never fitted ebc blue stuff endurance pads. Standard discs no lip. Sliders will be cleaned and regreased b4 sending. £200.
#772
Posted 04 March 2021 - 08:46 AM
I think 225 50s are too tall and will cause massive rubbing issues..
#773
Posted 04 March 2021 - 08:49 AM
#774
Posted 04 March 2021 - 08:58 AM
They are approx 1" taller than 225 45 15s, you may need to jack the ride height up a bit if you can...
#775
Posted 04 March 2021 - 09:12 AM
Time will tell. Ive been helping my mate fit btcc slicks on a bmw compact so if i can get that to work the 5 should be fine. Lol...worse case scenario ill take the battery angle grinder to Thruxton.
#776
Posted Yesterday, 12:30 PM
Ive just taken delivery of a full Kraken system and high mount manifold to replace my BEGi set up. It's nice kit and came beautifully packaged. What I do find a bit strange is that it looks different to yours where the kraken logo is - lacks the raise background. I wont be happy if I have to start altering the bodywork to make it fit.
I can't believe youve got so much weight out of it - that will be a real weapon.
Ben
#777
Posted Yesterday, 12:49 PM
Apparently mine is latest version after a recasting.
Im using my original downpipe so youll be fine.
#778
Posted Today, 09:35 AM
#779
Posted Today, 09:36 AM
