Tyres For Going From 16" To 15" - Wheels, Tyres, Suspension & handling/etc - MX5Nutz Forum
wheels tyres wheels 15 16 tyres
4 replies to this topic
#1 Trebor122
Trebor122
    One post wonder
  • 2 posts
Posted 23 April 2021 - 04:27 PM
Hi All,
I have a mk2.5 nevada with 16in wheels.
After reviewing the forums and willtheyfit.com, I have decided to go for some 15x8.
My issue is finding the wheel size to retain overall diameter for the speedo. This would mean a 215 50 r15 tyre, I think? however I am struggling to find a good road (and occasional track) tyre in this size. Also, finding a tyre online is one thing, but I need somewhere that will fit them too.
Any tyre size, make and model would be really appreciated. I am happy to do some arch rolling if needed.
Thanks,
#2 Shadowraven
Shadowraven
  • 4785 posts
Posted 23 April 2021 - 04:53 PM
you're looking at a slightly stretched 195/50/15 or a meaty 225/45/15 to retain the same rolling diameter on 15x8.
As for fitment, 15x9 et 36 is your limit, use willtheyfit.com to check things fall within that and you'll be ok. You might need to remove the liner and the size assumes you have coilovers (wont clear the wider stock suspension) but you wont need to roll or pull the arches. If you are willing to though you can run up to 245/40/15s, which are £££££ and very uncommon in the UK anyway. 15x8 et 25 is a safe size that will fit most 195-225 tyres without issue on an NB.
#3 Trebor122
Trebor122
    One post wonder
  • 2 posts
Posted 24 April 2021 - 03:55 PM
Thanks Shadowraven.
The 15x8 et28s are purchased and in the post.
So i will look for some 215 45 r15.
The usual recommendations seem to be toyo tr1 or nankang ns2-r, but seems to be a struggle to find sizes online. any recommendations on suppliers and fitter?
#4 Mr_Sukebe
Mr_Sukebe
  • 59 posts
Posted 24 April 2021 - 05:24 PM
Thanks Shadowraven.
My suggestion is to look on Asdatyres, who tend to have good prices.  Find their local to you fitter, then approach the fitter directly and offer him what Asda would have charged you, such that he gets the amount that Asda would have paid him, plus Asda's profit/cut.
#5 Shadowraven
Shadowraven
  • 4785 posts
Posted 24 April 2021 - 07:15 PM
Ns2-R are really very very good tyres and last a surprisingly long time. I'd get them if you can.
Also tagged with one or more of these keywords: wheels tyres, wheels 15 16 tyres
