1.8 Na M62 Supercharger Build - Forced Induction & N/A Power Mods - MX5Nutz Forum
138 replies to this topic
#1 Hexxeh
Hexxeh
  • 56 posts
Posted 12 April 2021 - 11:37 AM
So having had my 1.8 NA for ~6 years now, I'm hungry for a bit more power...
I'm looking at adding an Eaton M62 supercharger. I know the M45 is a popular option too but the units I can find for sale are roughly the same price and the M62 will be better sized to match the 1.8 and run more comfortably from what I can tell?
Has anyone done this on an NA with the wider ABS box? Looks like it's possibly going to be a tight fit for the inlet...
I've ordered the charger from eBay so we'll find out by the weekend all being well either way... :D
Parts list so far:
- ME442 ECU
- M62 charger (Merc version with the electric clutch, which I'll need to sort wiring for)
- Mounting bracket/inlet/outlet from Edd Kellet/Garage42
- Mini R53 bypass valve
- 1.6 throttle body for SC inlet
- ProRam cone filter
- Bosch wideband O2 sensor (from ME)
- IAT sensor (from ME)
Haven't picked pipes/fittings/belt yet since I'll start fitting it in place and figure out what's needed from there. Also thinking it might be a good idea to get the ME442 first up and running NA before fitting the new bits.
#2 Shadowraven
Shadowraven
  • 4815 posts
Posted 12 April 2021 - 03:38 PM
Im doing the same but welding up the garage42 kit myself. I'm keeping a load of the extras (AC, PS, racingbeat intake, strut bar etc) so clearance for me is proper shite, I've a 4-1 header as well. I have just got the inlet tac'd up and need to weld it properly over the next week or so, i'll post pictures once I'm done but it will give you an idea of the complexity needed (it's like 13 pie cuts). It likely could have been made more efficiently but I've not got the experience.
I don't know how the G42 kit inlet comes as standard, but you might be able to get away with using something like this to clear the ABS
https://www.ebay.co....ar=493237422322
Have you decided on a power goal and pulley size? I'd be interested to hear of any information you have?
#3 Hexxeh
Hexxeh
  • 56 posts
Posted 12 April 2021 - 03:49 PM
Edd's pretty local to me so he's kindly suggested I can bring the car down and we can test fit a bracket see how it fits, and come up with something custom hopefully if it doesn't. Would be interested to see some photos of how your's looks once it's together though!
No real power target as such: nothing too crazy, whatever it ends up with is likely to still be a very healthy bump! Mostly just want to keep it safe for the engine and reliable.
Not sure about pulley yet.
#4 Shadowraven
Shadowraven
  • 4815 posts
Posted 12 April 2021 - 09:22 PM
Nice. Where about are you? I've done the inlet now but it's far from pretty, pics on my build thread if you are interested (link in sig)
#5 Hexxeh
Hexxeh
  • 56 posts
Posted 13 April 2021 - 09:27 AM
NW England. Wow yeah those pictures of it in place show just how tight a fit it really is!
Parts started arriving for me today, got the K&N cone, mini bypass valve and the 1.6 throttle body (which needs a damn good clean up!). M62 should arrive tomorrow.
#6 Shadowraven
Shadowraven
  • 4815 posts
Posted 13 April 2021 - 01:51 PM
Yeh it really wasnt fun trying to align everything. It's unlikely you have the same limitations as me so you should have no issues and I see plenty of people use the coupler I linked to reverse the direction of the inlet. I can likely measure out the dimensions for you if you wanted to make a template before buying?
#7 Hexxeh
Hexxeh
  • 56 posts
Posted 13 April 2021 - 05:27 PM
Ordered a coupler, will just give it a go see what happens. ME442 ordered today, so I'll get that installed and running NA I think once it arrives to remove one more variable once the SC goes in.
Looked into pulleys today: seems to be a lot less info around for the M62 vs the M45. Seems to be the stock pulley is around 93mm, so that'd be about 10K RPM on the SC with a 130mm crank pulley based on the info here, but I'm not sure what that means yet in terms of boost.
Seems to be that if you want to replace the pulley, you have to remove the clutch mechanism too (apparently the entire snout can be swapped for an M45 one which is smaller and has no clutch).
I was hoping I could keep the clutch mechanism, since I hear it can be linked into the ECU to cut the drive to the SC at low revs. Once I've figured out what this is going to net me as is, it seems perhaps getting the pulley machined down if possible to retain the splines for the clutch but increase the ratio might be a good option if I can find somebody local with the skills/tools for that.
Edit: Looks like https://www.mx5nutz....opic=348425&hl= ran this setup on a 1.8 NB, and got ~7psi and 171bhp, sounds like a good result to me!
#8 Shadowraven
Shadowraven
  • 4815 posts
Posted 13 April 2021 - 07:35 PM
Double post
#9 Shadowraven
Shadowraven
  • 4815 posts
Posted 13 April 2021 - 07:36 PM
You can't machine the stock clutch pulley. You won't need the clutch if you have the mini bypass, they do similar things. Swapping the snout also won't work as the m45 is much longer so won't line up with the brackets / belts. Removing the clutch assembly is super easy.
I went 67mm to keep to the safe stock 14k charger limit, although short term to 15-16k are meant to be OK and Iv seen a number running 59mm. Efficiency seems to drop off really badly as you get close to 14k rpm so I also didn't see the point. I'm hoping for about 10-11psi and 200-220whp, but there's so little info it's hard to tell, based on a dyno of 65mm I should make the power I want.
#10 Hexxeh
Hexxeh
  • 56 posts
Posted 14 April 2021 - 10:37 PM
Hmm what stops you machining it? It arrived today so now I have it in hand, I can see the front pulley has a cover on it that seems to form part of the clutch mechanism. With no power supplied, the front cover spins the rotors, but spinning the pulley itself doesn't. Couldn't the mechanism be disassembled, and then only the inner pulley machined down slightly? I haven't attempted to disassemble it yet, so apologies if there's something obvious inside at the front that makes it impossible I'm missing.
I see you've stripped yours down, are you replacing bearings or just the oil? I see there's a few different kits on eBay with bearings but most of them claim not to be compatible with the clutched version. It'd be nice to disassemble it so I can clean the casing up, since it arrived almost black! Gave it a bit of a wire brushing/degreasing and it's a bit better...
Tiniest bit of play if you try to move the pulley laterally, otherwise seems pretty damn smooth.
#11 Shadowraven
Shadowraven
  • 4815 posts
Posted 14 April 2021 - 10:51 PM
Im not doing bearings as mine is in really good shape so not needed.
The pulley comes apart easy, but the outer bit isnt very thick if I remember, at 95mm diameter you couldn't take enough off the stock outer to make it worth it, you can get custom pulleys from ebay. You also cant machine the inner bit down, it wouldn't fixed properly and wouldn't have the bearing etc it'd need.
I finally got some info on pulley sizes today, still not complete but 67mm is looking like it'll make 210-230whp and about 200ftlbs.
Splitting the charger itself isn't too hard, once the pulley is off the nose comes off and then the rotor pack can be removed. That'd allow you to fully clean it inside. Do not get cleaning products on the rotors, they can react and remove the coating. Once split you'll also need anaerobic sealant to reassemble it. My plan for cleaning is to attach the stock inlet and outlet (nice long pipes away from the charger body), seal the ends so no water can get in and pressure wash it.
#12 Hexxeh
Hexxeh
  • 56 posts
Posted 14 April 2021 - 10:58 PM
Ah, that makes sense. How does it come apart? 8mm on the front and tap off? I'm a bit wary of taking it apart before it's on the car running and confirmed working so I was thinking to assemble everything once, check everything sounds healthy enough with the stock pulley, oil as is etc before replacing either.
#13 Shadowraven
Shadowraven
  • 4815 posts
Posted 14 April 2021 - 11:39 PM
Sounds a good idea. I just had time to kill. Mine is only loosely back together, not sealed and no oil. It's just like this for mock up purposes as im putting the bracket kit together myself and it's likely some debris might get in the housing. I'll clean it out properly and seal/paint it before it goes on.
IIRC the pulley is taken off by removing the 8mm, removing that cover, then there are some bolts under it to remove and a snap ring, everything should then slide off.
#14 Hexxeh
Hexxeh
  • 56 posts
Posted 15 April 2021 - 09:16 AM
Ah, I'll see if I can whip the pulley off then clean behind it a bit. I saw some mention on a forum post (which I now can't find the link for) of some small shims behind there, sounded like the kind of thing liable to pop out and be a bugger to get back in!
BoostTech replied, they do make a full service kit for the clutched version, so I've ordered one ready for that stage (https://www.ebay.co....tm/174153387789).
#15 Shadowraven
Shadowraven
  • 4815 posts
Posted 15 April 2021 - 09:32 AM
Yeh there are meant to be some shims, I didn't pay much attention as i'm swapping the pulley but it's easy enough to take things off and stack them in order, they shouldn't fly off anywhere.
I've heard of that kit, people seem to pretty happy with it.
#16 Hexxeh
Hexxeh
  • 56 posts
Posted 16 April 2021 - 11:13 AM
A few more bits arrived yesterday/today, got the oil/seals for the M62 from BoostTech, throttle cable kit, hoses/fittings, hose take off for the IAT and crankcase breather filter.
ME442 is arriving later today, IAT should arrive tomorrow and I'm picking up the crossover pipe to go with the elbows from a local supplier tonight.
Just the brackets/inlet/outlet left to collect once they're ready then and I think I've got everything to start test fitting everything together and see what's missing!
I ordered some RX8 injectors too incase I need them later on, they claimed to be "remanufactured and flow tested", but with so many fakes about I'm still wary, so we'll see what those are like once they show up.
#17 Shadowraven
Shadowraven
  • 4815 posts
Posted 16 April 2021 - 11:19 AM
Looks good. I'll be interested to see how your outlet and hoses line up, mine are going to be really difficult. I came across a BBR manual last night which show how I could have routed a FMIC over the rad which I sort of wish I'd gone with now.
#18 Hexxeh
Hexxeh
  • 56 posts
Posted 16 April 2021 - 11:30 AM
I took some guesses hosing/piping wise based on photos of other builds and info I found online. Went for a 400x76mm crossover pipe, 63mm/76mm 90deg for the original TB to crossover, and 60mm/76mm 90deg for the crossover to charger outlet. I'm told you need a 38->42mm reducer for the bypass connection too, but I think the one I have might be too big. Might cut down and be okay if the fixed diameter ends are long enough, but the T-bolt clips are probably a bit too wide to fit...
I thought originally you'd need to cut near the slam panel to fit an intercooler, but I've seen some setups that go down and around instead, which are interesting. People still seem to drill for threaded bolts to mount it on though. I really don't want to modify the shell, so I've avoided the intercooler for now, but I might explore it by making a plate that adapts from the existing holes in that area or something?
Gonna see what the intake temps are like without to start with though.
#19 Shadowraven
Shadowraven
  • 4815 posts
Posted 16 April 2021 - 12:20 PM
My bypass connector is just a bit of 38mm ID silicon. It's a tight fit to the bypass but otherwise fine.
I'm going to go down and around, but even with 2" pipe its going to be a really tight fit on the charger side due to the PS and pulleys (PS and AC). I'm going to modify the PS lines/cooler to get a little more space but I doubt it'll actually make much more, it'll just allow relocating the cooler to be done easier. You have an NA so going over the rad and using the 2 holes in the slam panel should be easy enough for you, I'm not sure what clearance is needed on the bonnet though, worth checking.
There are a number of ways to mount the IC. You can use the PS cooler line holes behind the slam panel, the AC mounting tabs, the horn mounting holes, drill the slam panel, use some of the existing holes in the slam panel, slip some flat bar between the bonnet catch and slam panel (im likely to do this) etc.
I think with the stock pulley you'll be fine IAT wise. Chargers dont compress air like a turbo, they displace it, so you don't get the same sort of heating of the charge as with a turbo. The other option is an air to water charge cooler. You basically have a barrel style cross over pipe with water flowing through it and then fit a small radiator at the front of the car. If you dont have AC this would be really easy to plumb into the AC mounting tabs, but it is a little more expensive, a little less efficient and does require wiring in it's own water pump.
#20 Shadowraven
Shadowraven
  • 4815 posts
Posted 16 April 2021 - 12:23 PM
Have a look through this for some ideas
https://trackdograci...905ic/step1.htm
and page 23 of this
https://www.flyinmia.../all_turbos.pdf
