How To Move Driver Window Position As Not Flush - How do I... - MX5Nutz Forum
12 replies to this topic
#1 GeordieAl75
GeordieAl75
    One post wonder
  • 6 posts
Posted 15 October 2020 - 08:10 AM
Hi.
So my NB import let in a lot of water via the driver side window.
I have removed roof seals and adjusted the rails they sit on which helped loads when tested with garden hose, however the edge of the window doesn't sit flush in the seal (quater light side). The water gets in right up in the corner. The window basically needs pushing in left to make it snug).
Trouble is I have loosened as many bolts as I could but it won't move. Can anyone tell me how to achieve this? A pic showing which bolts to loosen would be great.
Thanks in advance. I have pics to explain if needed.
#2 GeordieAl75
GeordieAl75
    One post wonder
  • 6 posts
Posted 15 October 2020 - 08:34 PM
Anyone?
#3 dadbif
dadbif
  • 785 posts
Posted 15 October 2020 - 09:18 PM
Pictures?
#4 Zed.
Zed.
  • 1634 posts
Posted 15 October 2020 - 10:13 PM
theres window top-travel stops on the door, easily adjusted :thumb-up:
or you could search?
https://www.mx5nutz....showtopic=96098
Bodger :ph34r:
#5 GeordieAl75
GeordieAl75
    One post wonder
  • 6 posts
Posted 16 October 2020 - 01:23 AM
Its not top travel. I did that already.
Nothing in my post mentioned height.
#6 GeordieAl75
GeordieAl75
    One post wonder
  • 6 posts
And I did search.......
#7 Rasc
Rasc
  • 2682 posts
Posted 16 October 2020 - 08:08 AM
I think people are struggling to understand the issue in detail. A quick pic with arrows pointing to the leak would be beneficial in you getting an answer.
MK1 RS Ltd, Turbo, Tien Super Sport, Recaro's, BBS, 227 WHP
MK2 RS White, HKS turbo, Koni sports, Watanabe's
MK2 VS White, HKS turbo, Miester Rs, 949 ULs
#8 dadbif
dadbif
  • 785 posts
Posted 16 October 2020 - 09:13 AM
As I understand it, the front edge of the window is not tight in the channel between the glass and the quarter light at the top?
#9 dadbif
dadbif
  • 785 posts
Posted 16 October 2020 - 09:28 AM
Open your door, underneath the door at the rear is an adjustable bolt
#10 GeordieAl75
GeordieAl75
    One post wonder
  • 6 posts
Posted 16 October 2020 - 11:56 AM
Thanks for replying.
Here is a pic of where the water comes in and how the window sits in the trim currently.
I want to get the window to sit within the trim.
Leak
https://pasteboard.co/JvUbgc0.jpg
Window
https://pasteboard.co/JvUayOE1.jpg
#11 GeordieAl75
GeordieAl75
    One post wonder
  • 6 posts
Posted 16 October 2020 - 11:57 AM
Yes sir!!
#12 GeordieAl75
GeordieAl75
    One post wonder
  • 6 posts
Posted 16 October 2020 - 12:00 PM
Thanks. So is it just one bolt I need to loosen and its the one closest to the back end of the door (closest to seat belt post?).
Or is there more to loosen?
#13 dadbif
dadbif
  • 785 posts
Posted 16 October 2020 - 09:10 PM
As I recall it is the single bolt underneath the rear of the door, slacken it off and you should be able to move the window glass frame to solve your problem.
Let us know how you get on.
