How Much Difference Does An Extra 2Kg Per Wheel Actually Make? - Wheels, Tyres, Suspension & handling/etc - MX5Nutz Forum
12 replies to this topic
#1 scoob101
scoob101
  • 67 posts
Posted 13 October 2020 - 08:55 AM
I really like the look (and price!) of these rims but they weigh 6.93kg each, which traditional wisdom says is a little on the heavy side for an NA.
My 1991 NA will be FI`d to about 190 WHP in Jan - so the car wont be sluggish off the line with heaver wheels, - but what about heavier wheels for general handling?
These Konig Heliums are a much more svelt 5KG. Quite a bit more pricy tho...
#2 Zed.
Zed.
  • 1617 posts
Posted 13 October 2020 - 10:44 AM
reserch unsprung wieght :unsure:
the hevier the wheels / tures the more the dampers have to work to control evrything...
Bodger :ph34r:
#3 scoob101
scoob101
  • 67 posts
Posted 13 October 2020 - 10:54 AM
Thanks - I found this which suggests to me that I shouldn't worry too much. Given I`m talking about a paltry 2kg a wheel - and the below tests were done with an additional 5kg a corner I`m wondering if the extra 300 odd quid for lighter wheels is simply wasted money. I do care about turn in performance of course, but at this point its hard for me to quantify if the heaver wheels I`m considering will even be noticeably worse.
https://grassrootsmo...-really-better/
#4 Shadowraven
Shadowraven
  • 4501 posts
Posted 13 October 2020 - 01:06 PM
Rule of thumb is multiply by 10, so 2kg per wheel would feel similar to removing 80kg of weight from the car.
#5 Shadowraven
Shadowraven
  • 4501 posts
Posted 13 October 2020 - 01:31 PM
Another point of note is that of tyre weights, they can vary considerably, my rainsports are only a few kg each whereas my nankangs are much much heavier. Every little helps but wheels and tyre weights should be considered in combination.
#6 Quinvy
Quinvy
    Phil.
  • 1808 posts
Posted 13 October 2020 - 08:32 PM
I never realised the substantial difference in weight between different brands of tyre, until I had to throw out all the tyres from the dealership where I was working. It really is astonishing. The same goes for sidewalls too.
I often wonder what the highly modified cars are like to drive. You know the youngsters with the body kits, wheel arches, huge width wheels et0 etc.
#7 MR Wallace
MR Wallace
  • 405 posts
Posted 14 October 2020 - 08:44 AM
I went from 7.9kg wheels to 5.0kg wheels fitted with the same tyres and the difference was immediately noticeable just driving out the fitting place, the car dealt with potholes and bumps much better, at speed it generally felt "lighter on its feet" and more nimble. Performance wise I didn't notice a huge difference but as your link above shows there will be some.
For just the general feel on normal driving it's definitely worth it.
#8 scoob101
scoob101
  • 67 posts
Posted 14 October 2020 - 08:46 AM
Thanks, this was exactly the kind of experience I was looking for.
I need to weigh my wheels......
#9 B_hawk111
B_hawk111
  • 630 posts
Posted 14 October 2020 - 10:01 AM
The difference between my rotas fitted with proxes and the same wheel fitted with the giti semi slicks is mad! I need to weigh the rotas with semi slicks vs the e30 bbs wheels with road tyres, as the bbs feel substantially lighter! Probably half the reason the feel so much better on the road!
#10 Zed.
Zed.
  • 1617 posts
Posted 14 October 2020 - 10:06 AM
I thought the e30 bbs wheels were heavy :blink:
Bodger :ph34r:
#11 Shadowraven
Shadowraven
  • 4501 posts
Posted 14 October 2020 - 10:30 AM
It is mad, I know my nangkangs are about 5kg heavier per tyre than my rainsports.
My nangkangs and SA3Rs (195/50/15) are nearly the same weight as my stock celica 205/45/17 with all seasons.
#12 dadbif
dadbif
  • 775 posts
Posted 14 October 2020 - 03:43 PM
A bit of reading
https://www.miata.ne...el_weights.html
#13 B_hawk111
B_hawk111
  • 630 posts
Posted 14 October 2020 - 04:25 PM
I don't know to be honest, haven't weighed them yet, but they certainly seem lighter than the rotas with semi slicks!
