4.3:1 Torsen Differential? - Mechanical & Electrical - MX5Nutz Forum
differential Torsen
23 replies to this topic
#1 zepic
zepic
    One post wonder
  • 6 posts
Posted 07 April 2021 - 09:56 AM
Hello, I have been on the search for a 4.3:1 Torsen diff on ebay and gumtree. To replace the viscous LSD in my 1992 which is a 4.3:1. But all the ones I can find are Either 4.1:1, 3.9:1 or 3.6:1. Does anyone know where I could find one?
#2 Zed.
Zed.
  • 2030 posts
Posted 07 April 2021 - 11:17 AM
believe the 4.3 with a torsen was only in a few less common 'specials'?
probably easier to find a 4.3 open diff (from a mk2 1.6?) then fit a torsen :mellow:
although the prices on a used (worn) torsen I'd look at a new plate Lsd from 3J's :yes:
Bodger :ph34r:
#3 boosted
boosted
  • 2080 posts
Posted 07 April 2021 - 11:29 AM
Mk1 eunos S special type 2 has 4.3 lsd. Very rare car. Specialist breakers poss.
#4 tony100
tony100
  • 99 posts
Posted 07 April 2021 - 11:54 AM
Good luck
#5 zepic
zepic
    One post wonder
  • 6 posts
Posted 07 April 2021 - 05:18 PM
Well this is not going to be fun trying to hunt down the rare 4.3:1 torsen diff.
#6 noobie
noobie
  • 867 posts
Posted 08 April 2021 - 07:53 AM
I think the 1.6NB's were 4.1 in Europe too.
Base NB8's in the US got the 4.3 as standard, so that's your best bet for a ring and pinion set.
There is the 1.6 small pumpkin sized mazdaspeed plate-lsd too. Tend to be cheaper than torsens nowadays and 4.3
I would just go with a standard 4.1 OP. The difference is tiny. Speedo gears are also easy to find.
#7 Zed.
Zed.
  • 2030 posts
Posted 08 April 2021 - 10:31 AM
https://www.flyinmia...vetrain/gearing
will show the overall speed differences :thumb-up:
the early (6") diff is showing it's age now  :yes:  that said all mx5 parts have had maybe 30 years use so I'd budget for a rebiuld on an old Lsd if not a torsen :popcorn:
Bodger :ph34r:
#8 zepic
zepic
    One post wonder
  • 6 posts
Posted 08 April 2021 - 06:47 PM
The thing is that I don't care about top speed but I do care a lot more about acceleration so keeping it at a 4.3 or even going up to a 4.4 would be good as a 4.1 would make my stock 1.6 slower.
Is it possible to buy any torsen and then change its pinion gear to get a ratio of 4.3 or 4.44?
#9 Zed.
Zed.
  • 2030 posts
Posted 08 April 2021 - 07:27 PM
Yep. :yes:
Bodger :ph34r:
#10 zepic
zepic
    One post wonder
  • 6 posts
Posted 08 April 2021 - 08:39 PM
Yep. :yes:
Would it fit together?
I have never seen this done before.
#11 Zed.
Zed.
  • 2030 posts
Posted 08 April 2021 - 08:59 PM
Yep. :yes:
you swap the crownwheel & pinion but it's a straightforeward process :)
for the post '93 '7"' diff theres ratio options of 4.4, 4.6, 4.778 & 5.1:1 available, some from early Kia Sportage front diffs.
I've built a 4.778:1 for my car...
Bodger :ph34r:
#12 noobie
noobie
  • 867 posts
Posted 09 April 2021 - 07:25 AM
If your name is Rich and you've done this a bazillion times.. Otherwise its really neither straightforward or cheap :) Still working up to doing this myself.
@OP: with stock 1.6 chassis and power you don't need a LSD. The chassis is so floppy that you nearly always have both rear wheels in contact with asphalt. I never had any trouble doing 4 wheel slides on track with both wheels powering the car (fully open diff). Like an Elise, std theory doesn't really apply like it would on say a BMW.
Its only once you go full cage/big power/drifting that diffs really become an advantage/must.
You'll end up paying between 600-1000gbp for the torsen,R&P+swap for nearly no benefit. Much better to save that money towards a Blink stage 1 or VVT swap if acceleration is your goal.
#13 Zed.
Zed.
  • 2030 posts
Posted 09 April 2021 - 08:42 AM
Ok, I'll admit it's at the sharper end of diy but I believe @Niklas has fitted a 3J's Lsd in his diff assembly so possible with some thought & tools.. B)
https://mighty5s.com/post/41459/thread
as example.... :thumb-up:
get a spare diff & be brave, whats the worst that could happen? :lol:
if you want som inspiration confusion theres some wanderings on my thread https://mighty5s.com/post/40218/thread and follows on the next page (after some waffling :whistle:https://mighty5s.com/post/40346/thread
Bodger :ph34r:
#14 Harvey_Tim
Harvey_Tim
  • 862 posts
Posted 09 April 2021 - 09:41 AM
Sorry to hijack this thread, but it is often said that a 30 year old Mazda VLSD will no longer be functioning but is there anything that can be done to refresh / rebuild these as they are obviously a lot more common / cheaper than Torsens?
1990 Classic Red 1.6 Eunos Roadster : Rebuilt LNC engine. Eaton M45 Supercharger, TR Lane mount, tensioner, inlet and outlet, Dual Throttle Body, Alta 15% Reduction Pulley (8-9 psi), Forge Motorsport Dual Piston Dump Valve, Deatschwerks 350cc Injectors, Magnecor 8.5mm Competition HT Leads, MegaSquirt 1 v3 ECU (Dyno tuned by Skuzzle to 205bhp), BMW vtps, Skuzzle FMIC, 50mm Alloy Radiator, Mocal 16 Row Oil Cooler with Thermostatic takeoff, XTD Lighweight Flywheel, Exedy Stage 1 Clutch, Hel Braided Clutch Line, JDM 4-2-1 Exhaust Manifold (Maxim Works Copy), Cobalt Stainless Steel Single Exit Exhaust System, RamAir Induction, Meister-R Zeta S Coilovers, IL Motorsport Front and Rear Chassis Braces, OEM Strut Brace, TR Lane GPD Roll Bar, Harness Bar and Door Bars, TRS 4 Point Harnesses, Sparco Sprint Junior Bucket Seats, Wilwood Dynalite 4 pot front calipers and rear 1.8 "Big Brake" Conversion and HEL Braided Stainless Brake Hoses, 15" Team Dynamic Pro Race Alloys, 17mm Spacers, Hankook Ventus V12 Evo 195x50 Tyres, "Carbing Style" Front and Rear Stainless Steel Tow Eyes, GV Style Front Lip Spoiler, Feed Style Side Skirts, Full Badge and Side Reflector Delete, Cut Rear Bumper, Smoothed In 'Firefly XL' Ducktail Spoiler, Mesh Vent TSI's with Eagle Eye LED Side Lights & Indicators, Fog Light relocated to Reverse Light Mod, "Flash to Pass" Mod, Bonnet Lifter Struts, Flocked Instrument Binnacle, Alloy Washer Tank, Sequential Shift Light, Racelogic GPS data logger, S2000 Start Button, Additional Guages (digital), Linx 1010 Tablet for Megasquirt Dashboard, Relocated 12v Lighter & USB Charger Sockets.
Build Thread : [size=2]https://www.mx5nutz.com/forum/index.php?showtopic=106875[/color]
#15 tony100
tony100
  • 99 posts
Posted 09 April 2021 - 09:54 AM
Bump....
I've seen some race cars mention rebuilt 'Barra' diff. Literally no idea what this means but pretty sure they need to keep the vlsd to meet the regs.
Does seem to be a gap in the market now as torsens are silly money and unlikely to retain the ratio for most 1.6 cars.
Does anyone know if these rare mazdaspeed (kaaz?) plated diffs are compatible with the vlsd gears and shafts?
#16 noobie
noobie
  • 867 posts
Posted 09 April 2021 - 07:02 PM
4.3 torsen on the FB-marketplace now. Pretty cheap too.
#17 tony100
tony100
  • 99 posts
Posted 09 April 2021 - 07:35 PM
Link or it didn't happen
#18 zepic
zepic
    One post wonder
  • 6 posts
Posted 09 April 2021 - 11:12 PM
Found a 4.3 open diff on FB but its all the way down in Ashford. Is that the one you are talking about?
#19 Bol
Bol
  • 151 posts
Posted 10 April 2021 - 05:38 AM
I sold mine last year and swapped it for a 3.6 that better suited my supercharger. They came on most late imports; not just specials. My car is an Eunos S-Package, of which there are still quite a lot about. Often people don’t realise what they’ve got.
#20 boosted
boosted
  • 2080 posts
Posted 10 April 2021 - 05:57 AM
Also tagged with one or more of these keywords: differential, Torsen
