14 Degree Mod And Standalone Ecu - Forced Induction & N/A Power Mods - MX5Nutz Forum
16 replies to this topic
#1 jdmtomd
jdmtomd
    One post wonder
  • 6 posts
Posted 09 March 2021 - 06:11 AM
Morning all,
Ordered my standalon ecu last night in preperation for turbo fun times later in the year.
Going to be running it on the car whilst it is N/A though for a few months.
I currently have the 14 degree timing mod on the car. Before fitting the ECU should I dial this back to stock?
Thanks in advance !
#2 dadbif
dadbif
  • 918 posts
Posted 09 March 2021 - 08:13 AM
Not necessarily, you will have to reset the timing during the initial setup sequence with the new ECU.
Do it once, do it right.
#3 jdmtomd
jdmtomd
    One post wonder
  • 6 posts
Posted 09 March 2021 - 08:39 AM
Sorry you have confused me a bit there, so when it comes to fitting ecu, I should set it back to 10btdc then?
#4 Zed.
Zed.
  • 2030 posts
Posted 09 March 2021 - 09:27 AM
Morning all,
Thanks in advance !
leave it as is :thumb-up:
the cas will supply the timing reference (wherever it is set.) and the standalone ecu will use the reference to understand the engines position in the firng cycle.
the ecu will then use it's programmed timing values from the timing reference to run the engine...
sorta :whistle:
also, what ecu have you gone for (out of idle interest :popcorn: )
Bodger :ph34r:
#5 jdmtomd
jdmtomd
    One post wonder
  • 6 posts
Posted 09 March 2021 - 10:52 AM
Morning all,
Thanks in advance !
sorta :whistle:
Thanking you!
I have gone speeduino. Cos I'm a poor ass peasant 🤣
#6 Zed.
Zed.
  • 2030 posts
Posted 09 March 2021 - 11:02 AM
nothing wrong with Speeduino, seems to work & not seen any complaints or criticisms about them B)
seem to have good options / outputs & background code is simple enough....
what ecu have you bought?
I'm seriously interested in Speeduino but my car is needing other things before an ecu so can see peoples experiences :popcorn:
Bodger :ph34r:
#7 Shadowraven
Shadowraven
  • 4671 posts
Posted 09 March 2021 - 11:24 AM
I just bought a Speedunio as well, tbh I can't really see why it's not a great choice for a street car that doesn't need flat shift etc. Zed, I'll be posting about it on my build thread as I progress so there'll be info there at some point.
#8 Zed.
Zed.
  • 2030 posts
Posted 09 March 2021 - 11:52 AM
been watching & waiting...
hurryup :blob:
Bodger :ph34r:
#9 Shadowraven
Shadowraven
  • 4671 posts
Posted 09 March 2021 - 12:26 PM
hurryup :blob:
Yeh money is a little tight atm. Need the M45 kit to sell, and then to make and sell the second with the teflon charger and can start the M62 build. Good news is I have a lot of holiday to use once the weather picks up lol.
#10 jdmtomd
jdmtomd
    One post wonder
  • 6 posts
Posted 09 March 2021 - 12:39 PM
I got the mx5 pack from diyefi. Congress with all the major bits needed so was very handy.
Hopefully will have it this week so will post experience with it 😁
#11 Zed.
Zed.
  • 2030 posts
Posted 09 March 2021 - 01:25 PM
:thumb-up:
keep up with updates & experiences B)
Bodger :ph34r:
#12 dadbif
dadbif
  • 918 posts
Posted 09 March 2021 - 02:48 PM
You will have to calibrate the ignition timing to sync with the ECU so that all the ignition timing maps read correctly, if you don’t and for example just plug it in with your base timing at set 14 degrees your ignition map may show 10 degrees but in fact be more advanced.
It is one of the basic settings in megasquirt etc, and I would assume likewise in Speeduino, I think Speeduino uses Tunerstudio as well??
#13 DarrenC95
DarrenC95
  • 13 posts
Posted 09 March 2021 - 02:59 PM
I'm also gonna be buying from DIY EFI I'm going with the DIY EFI Core-4 Unit as yourselves I'm on a budget an seems like a good option as its a road car which is my 2nd car an is rarely used so don't need to splash out on a expensive ECU
Sent from my SM-G975F using Tapatalk
#14 jdmtomd
jdmtomd
    One post wonder
  • 6 posts
Posted 10 March 2021 - 09:32 PM
Yep it also uses tunerstudio , I'll make sure that I focus and remember that when I do the set up 🤣
#15 Cliddoris
Cliddoris
  • 43 posts
Posted 10 March 2021 - 10:24 PM
I've no experience with speeduino, but in ME software there is a toggle to fix your engine to 10 degree firing.
Switch that on, use a timing light and either adjust the CAS until the timing mark meets 10 degrees or use the trigger offset and adjust it in software until the mark meets 10 degrees.
Quick job, I marked my CAS when I changed the CAS O-ring and matched the CAS up as best as possible, was still 4 degrees out.
Much easier if the speeduino allows you to adjust it in software, which given that it uses tuner studio I'd say there is.
#16 jdmtomd
jdmtomd
    One post wonder
  • 6 posts
Posted 11 March 2021 - 07:29 AM
Cheers for the info lads,
Looks like I will be all good to go once it arrives.
I have now started looking at things like coil on plug :/
#17 Phaeton
Phaeton
    One post wonder
  • 1 posts
Posted 14 March 2021 - 07:26 PM
What exactly are you selling & how much you wanting?
