Pop-Ups Lifting On Turning Ignition (1.6 Na '91 Uk) - Problems - MX5Nutz Forum
headlights electrical pop-ups
6 replies to this topic
#1 FleecyWelshGez
FleecyWelshGez
    One post wonder
  • 2 posts
Posted 18 May 2020 - 07:51 PM
Hi all, could do with a bit of help.
The car's been off the road sat for about 12 months when I first noticed this and I'm only reaching out now a few months later. The headlights used to only lift when I'd engage the sidelights or dipped regardless of the button on the dash. Now, whenever I turn the ignition (prior to engaging the starter motor) the headlights lift and won't go down even after playing with the dash button. If you turn off the headlights, they drop but instantly come back up, indicating some sort of "always on" signal somewhere in the wiring. The dash button works fine when the ignition's on, I just run into this problem once the car wakes up essentially. I've checked my earths and they all seem good, any suggestions on what to look for?
Thanks in advance,
Gez
#2 Zed.
Zed.
  • 1438 posts
Posted 18 May 2020 - 08:08 PM
what car? (UK or Jdm)
also
origonal spec or scene-tastic?
any wiring mods?
Bodger :ph34r:
#3 FleecyWelshGez
FleecyWelshGez
    One post wonder
  • 2 posts
Posted 18 May 2020 - 08:09 PM
also
It's a UK '91, No fancy electrics other than standard stuff, this issue cropped up after just being sat in a garage for a year
#4 carl s
carl s
  • 1573 posts
Posted 19 May 2020 - 08:07 AM
try here: https://forum.miata....ad.php?t=625696 could be the headlamp retract relay
ex - mk3 2006 2.0 sport
ex - mk2 1999 1.8is JRSC
#5 Martin Y
Martin Y
  • 10273 posts
Posted 20 May 2020 - 10:39 AM
So the dash switch works normally with the ignition off?  Not likely to be the switch then.
And whenever the ignition is on, it seems something is sending 12V to the "up" wire.  But when you turn the headlights off they retract momentarily.  That suggests that the Retract relay is able to switch to sending 12V on the "down" wire, which makes it less likely to be the cause of the permanent 12V on the "up " wire.
An added complication is UK cars "dim-dip" wiring; I've never seen a wiring diagram for how that works.
One thing that might be worth mentioning is that I've seen a few folk on the Nutz FB page saying their headlights get stuck up after they fit LED headlights but nobody's ever posted a solution and it's not clear if only dim-dip cars are affected.
If it helps, according to this: http://www.mellens.n...1991_wiring.pdf  the "up" wire from the dash switch is red/yellow and the "down" wire is red/green.  That red/green then goes to the Retract relay where it can be switched to the red/yellow wire to drive the lights up or white/red to drive the lights down.
Probably the obvious thing to try is unplugging the Retract relay to see if the permanent "up" command goes away.  If not it might be a wiring fault (nibbling mice?).
#6 Martin Y
Martin Y
  • 10273 posts
Posted 20 May 2020 - 10:49 AM
Oh, wait.  I may be overthinking it.
When the headlight motors finish popping up, they switch to look for 12V on their "down" wire instead.
If the Retract relay was working normally, they would see that "down" command and pop straight down again.  So the retract relay isn't sending them the expected down signal, so it probably is sending an up signal instead.  Might be a fault in the Retract relay, but might be a fault in the signal going to it instead (on a white/black wire).
#7 rjb
rjb
    One post wonder
  • 1 posts
Posted 12 June 2020 - 07:40 PM
Hi All,
Having the exact same issue with mine (1990 1.6) after fitting some questionable LED's from china
I have for some reason or another a dimly lit main beam on the dash (only visible when in my dark garage) so the lights motors are seeing 12v from somewhere, initially thought it was a short within the light itself being chinese specials, but even when i unplug them they pop up?
let me know how you got on
Reece
Also tagged with one or more of these keywords: headlights, electrical, pop-ups
