Replacement Jrsc And Mp62 Throttle Cable - Page 2 - Guides: Forced induction - MX5Nutz Forum - Page 2
29 replies to this topic
#21 Mr Slow
Mr Slow
  • Moderators
  • 19520 posts
Posted 22 March 2007 - 05:10 PM
Just had a call for the garage, mine is in stock ready to be collected, going to get it on Sat since (Unlike some) i can't have friday off, unless i'm ill :rolleyes:
Oh you Bastard, where's my call? !!!
#22 Mr Slow
Mr Slow
  • Moderators
  • 19520 posts
Posted 22 March 2007 - 05:31 PM
:( :( Not in stock yes, *may* arrive tomorrow, what a complete pain in the bum!
#23 Firestar_3x
Firestar_3x
    Bring it on baby!
  • 812 posts
Posted 22 March 2007 - 05:54 PM
Have you booked the time off to fit the SC tomorrow?
#24 Mr Slow
Mr Slow
  • Moderators
  • 19520 posts
Posted 22 March 2007 - 06:50 PM
yup!! arses!!
#25 Firestar_3x
Firestar_3x
    Bring it on baby!
  • 812 posts
Posted 23 March 2007 - 09:29 AM
yup!! arses!!
Well i think you should goto the garage and collect the one for :)
Let me know when yours turns up, means you can fit yours this weekend, i'm still waiting on my trackdog parts from rockdoc / usa anyways :)
#26 Firestar_3x
Firestar_3x
    Bring it on baby!
  • 812 posts
Posted 26 March 2007 - 06:01 PM
Got a call from the garage today, second on is in stock :)
#27 Daz
Daz
    AK47 - 9 out of 10 owners said their kitten preferred it!
  • Root Admin
  • 18088 posts
Posted 26 March 2007 - 06:12 PM
That was a very magnanimous thing do to Mark, you're a true gent :thumb-up:
Daz
Don't ask me, I don't work here any more.
#28 Mr Slow
Mr Slow
  • Moderators
  • 19520 posts
Posted 26 March 2007 - 07:04 PM
Daz
Indeed, and you can add that this cable fits the MP62, just!
#29 Gixer
Gixer
  • PipPipPipPipPipPipPipPipPipPipPipPip
  • 20813 posts
Posted 26 March 2007 - 07:07 PM
Is this the cable Phil sends out with his MP62 kits?
I naturally assumed a stock throttle cable from a LHD 5 would fit no?
Anyone tried one?
1994 V-Spec II, Auto, MP62 Hotside SC (6rib) 65/125 (10psi), Dual TB, 430cc RX8 Injectors, Zeitronix WB, EGT, MAP etc, XS KnockLite, Water Injection (Devils Own Pump, Aquamist HSV Go-kart tank 8.5L), Aquamist DDS3 V8, Custom IC and pipes, Hard Dog M2 Sport DD, FFS Dual Feed Fuel Rail, Torsen TypeII, Tein Flex, Axxis Ultimate pads, Rota RB 15x8, Toyo T1-R.
Posted Image My car blog
#30 Firestar_3x
Firestar_3x
    Bring it on baby!
  • 812 posts
Posted 28 March 2007 - 04:10 PM
:) glad to help out as ever, picked mine up today, ordered some gaskets whilst i was in the garage as well :)
#31 saboteur
saboteur
    One post wonder
  • 4 posts
Posted 27 January 2008 - 11:24 AM
Anyone tried one?
I tried one, and it's too short by about 300mm, as it stands my JRSC install is all done except the throttle! :wallbash:
Does anyone know what car the mentioned part number above is from?
Can't wait to go for a spin!
#32 saboteur
saboteur
    One post wonder
  • 4 posts
Posted 29 January 2008 - 10:14 PM
A mate of mine tracked down a new throttle cable for my install and he found one that is perfect, we fitted it yesterday. It has the same ends as the standard cable and has two metal brackets on it that are usually for the firewall but I used them on my cam cover to hold the cable neatly in place, looks like it was that way from the factory!
I don't know the part number but it was from a Mazda B2600 utility. I'll take a pic later to show you what it looks like installed.
#33 Fluke
Fluke
  • 2734 posts
Posted 12 November 2008 - 06:04 PM
Part number: FB44-41-66OC
Modifications required:
There's 2 brackets that are pressed on, these need prising off - easy enough. There's two other bits that need to be removed as well though. The first one is a pressed on 'stop' on the pedal end of the cable that's in the wrong position for a '5. Of course I discovered this AFTER I'd clipped it through the bulkhead so I had to go dicking about to undo the impossible-to-undo clips :rolleyes: For this, you need a workbench, a dremel, a grinding bit and a very fine precision screwdriver. Grind the stop away carefully, making sure you don't cut into the cable, just enough to be able to pry the remains of the stop off with the screwdriver. The other bit is a sleeve at the throttle end, which takes too much of the slack up. Undo all the bits so that you can get a hacksaw to it and cut this bit off, et Voila! One JRSC throttle cable
Price was a little under 40. Part arrived within 3 days, despite Mazda saying it might take 3 weeks.
Part is for a JRSC but also fits an MP62 (though apparently it's a bit tight)
Daz
Daz, I have just done part of this mod, do you have a picture showing the throttle end of the cable so that I can see what sleeve I need to cut off? Thanks.
2000 Mk2 1.6 - Jackson Racing M45 Supercharger - 62.5mm nose pulley - 150mm Crank Overlay - 550cc Bosch EV14's - Jackson Racing Air/Water intercooler - Dual Throttles - Megasquirt - AEM Boost Gauge - AEM Wideband - Borla Sports Duals
#34 carl s
carl s
  • 1580 posts
Posted 15 February 2009 - 04:51 PM
Just found this thread, I take it this brass bit is the offending stop which I need to remove ?
not sure mine has anything different from the normal one at the throttle end though.
ex - mk3 2006 2.0 sport
ex - mk2 1999 1.8is JRSC
#35 Daz
Daz
  • Root Admin
  • 18088 posts
Posted 15 February 2009 - 05:26 PM
Pic isn't showing so I can't tell you. As I said above, compare the old to the new.
Daz
#36 carl s
carl s
  • 1580 posts
Posted 15 February 2009 - 07:44 PM
should show pic now
#37 Gixer
Gixer
  • 20813 posts
Posted 15 February 2009 - 07:59 PM
should show pic now
:no:
