Body Panels - Exterior - MX5Nutz Forum
Body Panels
2 replies to this topic
#1 rock botulin
rock botulin
    One post wonder
  • 6 posts
Posted 09 April 2020 - 08:19 PM
Hi everyone
I need a boot lid and drivers side wing for my 98 mk2, I've seen a mk2.5 breaking on ebay and was wondering if anyone new if the panels are the same? Thanks in advance rick
#2 Shadowraven
Shadowraven
  • 4370 posts
Posted 11 April 2020 - 07:04 PM
They are. And this should be posted in the wanted section really.
#3 rock botulin
rock botulin
    One post wonder
  • 6 posts
Posted 14 April 2020 - 02:06 PM
Thanks mate appreciate the help
