Ardler AutomotiveAdvertise on MX5NutzMazda on TrackSky InsuranceWheels in MotionMX5 PartsAK AutomotiveRoddisons MotorsportOpie OilsMX5Nutz ShopDriftworks.comSportDriveMiata RoadsterGSM Performance
Diy Low Profiles....
215 replies to this topic
#1 Mauske
Mauske
  • 105 posts
Posted 25 October 2011 - 06:10 PM
So, that was a long time ago..
Last weak i was doing a big update on my MX5..
I made Low profile headlights by myself...
Buying new ones was to expensive for me so i made it myself.
First i had to find out how to make the lights going open less far...
That was no problem.. i shortened the bars in the headlight units and bend the pivots from the headlight motors.
I bought 2 headlights from a company in germany for under the 100 euro's...
This is the result :)
It not finished yet, i have to made something to make the side nice !
To see the difference between original and my DIY low profiles :
Mx-5 '91 Classic red..
#2 nmwisima
nmwisima
  • Registered Traders
  • 4045 posts
Posted 25 October 2011 - 06:21 PM
These look fantastic! :thumb-up:
#3 HMT
HMT
  • 667 posts
Posted 25 October 2011 - 06:24 PM
They do look great indeed! The angle is just perfect. Maybe you can use the OEM plastic frames and fuse them with some 323F BG frames (plastic welding and 2k plastic glue) to create a good fitting frame (which is usually lacking with low profiles, redering the side view awful...
#4 hooligan
hooligan
    internet warrior
  • 10918 posts
  • Interests:anything that begins with F.....
Posted 25 October 2011 - 06:31 PM
awesome.
link to lights........
#5 Ant.D
Ant.D
  • 75 posts
Posted 25 October 2011 - 06:40 PM
They look great :goodjob:
#6 hrg
hrg
  • 94 posts
Posted 25 October 2011 - 07:41 PM
Looks wicked, totally change the look.
Shouldnt be too difficult to make some covers for the sides...
#7 Mauske
Mauske
  • 105 posts
Posted 25 October 2011 - 07:45 PM
Because i'm on holiday at this moment, i have to post this from my Iphone..
I promes you to post a little story about how to make these low profiles.
And it is much easyer than it looks like..
Hopefully you can understand my bad English...
First i post the link for the light units, but if you want to order then, be aware of the side of driving..
You guys drive on the left side do you ?
Then you have to look for the LHD units....
http://www.teilesuch...213001?c=700243
More to come in the weekend.. :)
#8 corvin696
corvin696
  • 154 posts
  • Interests:Anything car related, women, alcohol and reptiles or other exotic pets.
Posted 25 October 2011 - 07:53 PM
I very interested in how you managed to do this as I want to make Summat very similar but using twin headlights 1 being high beam and 1 low beam.
#9 tomcat
tomcat
  • 2799 posts
Posted 25 October 2011 - 10:18 PM
great job there mate and alot cheaper than buying the already made kits!!
#10 Mr_Wolf_is_innocent
Mr_Wolf_is_innocent
    Wolfmeister
  • 758 posts
  • Interests:Cars, Driving, Kayaking, Animals, Computers, etc
Posted 26 October 2011 - 12:13 AM
Loving the new Lights.. I think there are several on here who would love a full "how to"..
could you modify the "cowls" from ford probe headlights? Just a thought.. (I have no idea if they will fit.. however I have considered buying a pair to try and do the same kind of thing..)
1.8 NC
1.6 NA, K&N style filter, Big Zorst. Skuzzle TSI's with LED's.Stainless Grill, P5 rails (yet to fit) Project car/toy. Weapon Style bar, Cusco Strut brace, Mr Fast Front lower brace, Flash to pass, Offset Plate Alloy Ball Gear Knob, Boot light, Stripping out..... Watch this space...
#11 Mauske
Mauske
  • 105 posts
Posted 26 October 2011 - 05:00 PM
Because of the reaction i have had on this topic, i tried to tell you how i did the job.
First i want to appologise about my english.. I'm better in Dutch.. :)
So, first i bought me a pair of headlight units from Hella.
I choose for the Hella units because of the road legal units...
In the Netherlands the car have to bring in once a year for an inspection..
So if the light beam isn't within the dutch rules, i may not drive the car anymore...
So i had to be sure i bought the right units..
Please be carefull when you order a couple of units, if you drive on the left side of the road you have to choose the units for left driving trafic.
After that i took o ut the headlight units.. Loosen the pushrod and the 2 bolds that holds the part were the round units are in.
So take out the round units...
Now you have to make a simple construction were you can bolt your new pair of units on.
I used a strip of aluminium.
That will look like this :
The angle of the front site of the construction has to be about 30 degrees..
This is the tricky part, because it can be 35 or maybe 27 degrees.. You have to try..
It's a little easier to try when the units are build into the car...
Before you can build them back into the car you have to shorten the pushrods..
I shortened them by 1.5 cm..
Then the most difficult part is about to come.
You have to shorten the pivots without damaging them.
Shorten them a full cm, beter 1.5 cm.....
On the picture i only shorten them a cm, but i bend it a little further...
Normal size..
The shortened pivots :
Now you can build in the headlights back into the car..
You wil see they wil open a lot less... But enough for the new units...
Do not forget to make the 'stops' a little longer, because otherwise the units will shake a lot....
If you bolt the new units onto your selfmade construction, please look if they are on the right level... How you call in in English, waterlevel ?
If they are not, the car wil look like a sad person.. :)
So far so good... Now i have to think about the sides... But i already have an idea how to do that...
To be continued....
So please if you do have a question please feel free to ask..
#12 da.murf
da.murf
  • 226 posts
  • Interests:Cars
    God
Posted 26 October 2011 - 05:15 PM
Very very good write up. Do u know the model numbers of the right style lights.
#13 Mauske
Mauske
  • 105 posts
Posted 26 October 2011 - 05:19 PM
Euh, no, i'm sorry... I am sure the store will sell them..l maybe someone who found the richt units will post it here...
#14 Mauske
Mauske
  • 105 posts
Posted 26 October 2011 - 05:23 PM
Damned, i writing this on an ipad, and i don't know why it is going wrong..
#15 Mauske
Mauske
  • 105 posts
Posted 26 October 2011 - 05:24 PM
Hmm post this twice ..... Why i did that ? I do'nt know... :)
#16 Mauske
Mauske
  • 105 posts
Posted 26 October 2011 - 05:26 PM
http://www.teilesuch...13047?c=700243.
Maybe you can use these... The size is the same... And it's for left driving trafic
#17 minto
minto
    Project-G!
  • 1135 posts
  • Interests:Drifting & Snowboarding.
Posted 26 October 2011 - 05:27 PM
Haha thats cool :) Iv been doing this mod aswell with some spare motors I have. I was planning on releasing a kit next year actually :) Thanks for the link i was looking for good lights.
[noOnefresher since1986 | Project-G | DAI-KO.network ]
#18 24R
24R
  • 299 posts
Posted 26 October 2011 - 11:40 PM
Awesome read. I've just bought some Ford probe head lights with plastic surrounds.. I'll let you know how I get on.
#19 Mauske
Mauske
  • 105 posts
Posted 27 October 2011 - 09:40 AM
Ford Probe units are much higher..
So you do not have the low profile look with it.. :(
#20 24R
24R
  • 299 posts
Posted 27 October 2011 - 10:08 AM
not so low profile as the lights you have but they are lower than the round mx5 lights which is what i'm after. ;)
