Rust - Another.... Will This Pass The Mot Thread!
10 replies to this topic
#1 seismic22
seismic22
  • 204 posts
Posted 09 August 2011 - 03:04 PM
Hi Guys,
Sorry to have to ask something thats always getting asked but i do need the advice.
Trying to get my 5 MOT'd and back on the road, getting sick of this FWD M'larkey!
The Offside sill is rusty. My fault. I have slowly let it rust through from outside in. When i first noticed it there was no hole, it had been subject to various scrapes and stone chips and the paint had peeled. Forward to a year later and running it as a daily driver, driving all over the country in the snow (it acted a s asnow plough most the time) on salty roads with none of the undersealing and rust protection I had planned and it now the outer sill section has rusted so bad i peeled a lump away.
Soooo I having been doing some investigating and the inner sill, though (as u can see) is a little corroded, is solid as. Ive prodded and poked it bloody loads and its fine, a clean up with the angle grinder and it should look ok, ive looked inside the sills (taken out the bung etc) and yes i can see very small amount of minor rust very near the rear end of the sill but the rest of the sill is very clean clean. My problem is, are the MOT chappies going to fail me on having an exposed inner sill even though its solid? Of course i am going to get the outer sill plated but I need to get it Mot'd to drive it somewhere to have it welded! I live to far from anywhere to get away with some careful cross fingers touch wood un mot'd and taxed driving roudn the corner to a welder/garage etc!
Please see picture below! Sorry for the essay i guess it shows how guilty i feel for letting it get this bad.! Arches all completely solid, inner and outer, not a spot, other than a small rust hole in bottom of front wing (getting changed!) this is the only rust!
#2 AndyMk2
AndyMk2
  • Moderators
  • 15,498 posts
Posted 09 August 2011 - 04:16 PM
Based on what we have seen in the past, that's pretty unlikely to be honest.
These cars rust from the inside out, it's always worse than it looks unfortunately.
#3 Garath
Garath
  • 3,355 posts
Posted 09 August 2011 - 04:25 PM
That will 100% fail the MOT I'm afraid
#4 IsoMX
IsoMX
    finds titles too "mainstream"
  • 5,173 posts
Posted 09 August 2011 - 09:19 PM
Yep.
Insta-fail for sure. Also expect to get it back from the mot station with a fucking great screw driver hole through it. They like doing that...
Mate of mine got a Ka back from MOT looking like swiss cheese when they failed it on rust.
Skuzzlecharged, Jass'd up, MX5Restored, Rodder's padded, 1996 Eunos Roadster, in the 'proper' colour ;)
I used to drive with an angel on one shoulder and a devil on the other, but then I swapped the devil for a supercharger whine and told the angel to get lost...
Also yes *technically* you could now say my car is wrapped in a giant plasti-dip condom. I prefer to look at it as my car now being multi-functional, it's a means of transportation that now doubles up as a giant pencil eraser!
Disclaimer: If you don't like my humour, just don't laugh. Simple, I won't be offended and would prefer it if you weren't either.
#5 Paul R
Paul R
  • 5,490 posts
Posted 09 August 2011 - 09:24 PM
Yep.
Mot testers are NOT allowed to use screwdrivers, we can only use the cat (Corrosion assessment tool)
#6 fergyuk
fergyuk
  • 752 posts
Posted 09 August 2011 - 09:27 PM
Yep.
which looks like a screwdriver on one end Posted Image
#7 IsoMX
IsoMX
  • 5,173 posts
Posted 09 August 2011 - 09:41 PM
Yep.
Well regardless of the tool, a ruddy great hole is a ruddy great hole!
#8 seismic22
seismic22
  • 204 posts
Posted 10 August 2011 - 07:17 AM
OK, if it is believed that this will not pass the mot then am I to assume then that the outer skin of the sill is considered structural?
The inner skin is 100% solid, I myself have poked it with a screw drive pretty hard all over and as mentioned looked inside the sill and it seems to be pretty clean.
Thanks for the replies!
#9 Garath
Garath
  • 3,355 posts
Posted 10 August 2011 - 09:10 AM
you make a good point, and its one that I always make, the outer skin is really a rear wing, it is spot welded on along the bottom edge, the structural sill is behind it, as you say, but, according to the MOT book, they can, and will fail it, because it is considered to be the sill, and to be honest any rust within 300mm of suspension mounts, or seatbelt mounts can be a fail, which could be anywere on an MX5 really, lol
so, long story short, it will fail I'm afraid
#10 judge1979
judge1979
  • 12 posts
Posted 10 August 2011 - 11:09 AM
as for the cat tool the pointed end is only to be used for a lever and light scraping not going hell for leather at rusty sills but it appears everyone does it!
#11 doctormx5
doctormx5
    One post wonder
  • 6 posts
Posted 11 August 2011 - 10:07 PM
It looks like about 150 worth of welding and repainting from this angle. That's for a flush 'invisible' repair. Some people get a plate stuck on top (which ought to be cheaper) but it looks N A S T Y
Julian
