Zetec Engine Swaps Into Mx5?
33 replies to this topic
#1 Philk
Philk
  • 85 posts
Posted 18 February 2011 - 04:09 PM
Hi there
I want to do an engine swap in my mx5, the main reason is I want a brand new engine but mx5 ones are expensive where as a b/new ford zetec 2.0 is 800 posted, and it has more power, and because ford/mazda engines are the same (up to certain years) it shud work. I will do it if i could find out about the fitting of the gearbox, does anyone know if it will meet up to the gearbox with no messing?
Many thanks.
#2 Road&ster
Road&ster
    Randomer
  • 8,007 posts
  • Gender:Not Telling
Posted 18 February 2011 - 04:17 PM
I got my last Mk1 mx5 engine for 200 + 60 delivery, how is that expensive? And cost wise it's better to add a turbo or SC to the existing Mazda engine.
I think there would be a lot more to think about, not just the gearbox mating up.
Have a read of this thread about the Ford Duratec/Zetec engine and mx5's (Clicky)
#3 H1CKY
H1CKY
  • 30 posts
Posted 18 February 2011 - 04:20 PM
:confused:
#4 ecksjay
ecksjay
  • 4,941 posts
Posted 18 February 2011 - 05:21 PM
if you're on about a mk3, it is technically a ford engine yes.
if you're on about mk2 or earlier, an engine is pennies. you obviously havent looked and have took dealer or garage quotes as gospel.
Mk2 Roadster RS Turbo
Mk2 Roadster VS Turbo
Mk2.5 Roadster RS N/A
#5 Palmer
Palmer
  • 83 posts
Posted 18 February 2011 - 07:03 PM
Mazda 1.8 dohc - 140bhp
Ford 2.0 Zetec - 130bhp
Says it all really
1996 UK Mk1 1.8
Style bars, momo steering wheel, OZ racing wheels, PAS fitted.
#6 Martin Y
Martin Y
  • 9,070 posts
Posted 19 February 2011 - 02:02 AM
What model of MX-5 are you trying to put this brand new engine into?
If it's a MK.3 then maybe a Duratec would fit, as Ford use that label on their built-under-license Mazda MZR engines. (AFAIK Ford don't label engines as "Zetec" any more - it's a trim spec they apply to cars).
If it's anything before a Mk.3 then definitely not. The Ford won't bolt up to the Mazda gearbox.
#7 Vindi (Russell)
Vindi (Russell)
  • 12,223 posts
Posted 19 February 2011 - 11:57 AM
Not sure if anyone else actually read the question, but the OP is after a Brand New engine... and he is correct the Ford engines are much cheaper than their Mazda equivalents.
The swap has been done, but the ones I've seen have done it using a Type 9 gearbox (Ford Sierra) and a custom prop (about 75).
Quite a bit of work involved and for my money I'd go with a Zetec out of an ST170 (5-700 odd for a 20k mile engine and 172bhp standard) or a Duratec 2.0 or 2.3 which are much more powerful and much more tuneable engines than the Zetec... costs are higher though.
Russell.
#8 Philk
Philk
  • 85 posts
Posted 19 February 2011 - 04:35 PM
I know there is a lot more to think about than the gearbox but that is my main concern b4 i even start. FI or supercharge is a gud idea but my car has 95k and what i wud like is full engine gasket set , which is also engine out job.
My car is mk1 1.8
Vindi49 has got it right, the reason why i want this is because i want a b/new engine, a st170 wud be nice but may be over priced. Thanx 4 the comments.
#9 al_p
al_p
  • 1,237 posts
Posted 19 February 2011 - 05:55 PM
swap like for like wats the point in spending a fortune on a slower engine to be fitted ??
st170 you will need the full loom engine new mounts custom exhaust manifold modified inlet manifold in other words alot of fabrication cost i think about £3000+
a new engine + supercharger on low amount of boost + good ecu would get you more power for under 2k
as for brand new engine you could probably renew all the internals of the std one still for cheaper than putting the st170 engine and fitting
Surely there must be something you can do.
I'm doing everything I can... and stop calling me Shirley!
#10 scubadog86
scubadog86
  • 279 posts
Posted 16 September 2012 - 03:08 PM
Surely their is no way you can even supercharge an mx5 for under 2k let alone engine and ecu????? I am after forced induction and been told and looked a new turbo kit is more like 2.5 k with the cast manifold and matching down pipe and been quoted almost double for a supercharger but if you are lucky enough to find a second hand one then it might be possible,plz if I am wrong send me in the rit direction to purchase supercharger/turbo for sub 2k
#11 Masaq
Masaq
    Anarcho-communist. Apparently.
  • 5,802 posts
Posted 16 September 2012 - 03:55 PM
Depends what you want to make, power-wise. 160-180bhp via a small turbo or m45 charger, not using a standalone ecu, no intercooler and no oil cooler, can certainly be done for under 2k if you source parts carefully. If you want big power and reliable big power at that - yes, you're talking more.
#12 sausages
sausages
  • 4,284 posts
Posted 16 September 2012 - 11:31 PM
You are 100% wrong I'm afraid. Look in the for sale section as supercharger / turbocharger kits often come up for a LOT less than a grand.
2003 Toyota Corolla Tsport
#13 Gixer
Gixer
  • PipPipPipPipPipPipPipPipPipPipPipPip
  • 20,813 posts
Posted 17 September 2012 - 03:02 AM
So you want to save a few hundred quid by buying a different more, but then spend 4 figures getting this engine to fit in a MX5
:doh:
As said you'll need engine mounts fabricated, ECU, wiring harness, gear box adaptor (or a different gearbox which will then need, prop shaft, possibly transmission tunnel mods, PPF, maybe even a new diff with a different final drive ratio)
Then there is the sump if you bought the motor in fwd configuration you'd need a custom sump for the MX5.
If your not doing it yourself i'd bet you won't get much change out of £5000 for a company to do the conversion, and for less power as well :doh:
Why do you want a brand new engine?
MX5 motors are pretty much bullet proof, there really is absolutely no need to buy a brand new engine.
I wouldn't even bother reconditioning a half decent 1.8 motor
I can understand if you had experience with zetec motors and wanted to have a play converting a mx5.
But to carry out the swap 100% to save money is crazy.
What's wrong with your current motor btw?
1994 V-Spec II, Auto, MP62 Hotside SC (6rib) 65/125 (10psi), Dual TB, 430cc RX8 Injectors, Zeitronix WB, EGT, MAP etc, XS KnockLite, Water Injection (Devils Own Pump, Aquamist HSV Go-kart tank 8.5L), Aquamist DDS3 V8, Custom IC and pipes, Hard Dog M2 Sport DD, FFS Dual Feed Fuel Rail, Torsen TypeII, Tein Flex, Axxis Ultimate pads, Rota RB 15x8, Toyo T1-R.
Posted Image My car blog
#14 Mr Slow
Mr Slow
  • Moderators
  • 19,520 posts
Posted 17 September 2012 - 07:55 AM
You think an engine swap is cheaper?
And don't use txt speak on the forum, you agreed not to when you signed up.
#15 DMRider_10
DMRider_10
  • 4,516 posts
Posted 17 September 2012 - 08:53 AM
This is just ridiculous
On my 9th Mx5.......Currently: Gold Mk2 RS,  Build thread http://www.mx5nutz.c...opic=235049&hl=
#16 Martin Y
Martin Y
  • 9,070 posts
Posted 17 September 2012 - 09:45 AM
Well it's not quite as bad as that, it's just misinformed.
The OP thought that a new Ford engine might bolt straight up to the MX-5 gearbox. Well, no it won't. A conversion to make it fit would cost multiple thousands and he knows that now. He also thought that a complete new gasket set would be advisible before adding FI to his original engine when in fact we know it's unnecessary. 95k miles is nothing on these engines, and they're sufficiently overbuilt that you can bolt on 200+ hp of forced induction with no fear for the internals.
For the OP: my Mk.1 1.8 engine had 120k miles on it when I supercharged it to 180+ hp. It didn't cause any problems and my experience seems to be pretty typical.
#17 Stinky
Stinky
  • 292 posts
Posted 22 June 2015 - 06:53 AM
Mine has over 100k miles and is making 300 un touched, these engines are awesome and crazy strong
#18 Coop.
Coop.
    Rob
  • 579 posts
Posted 22 June 2015 - 07:12 AM
Holy thread revival, Batman!
flickr
ニッパー  Progress thread
1991 NA6CE Eunos Roadster V-Special // MesiterR Zeta S // Skuzzle Fast Road geometry // Panasport Pro Rally
#19 Stinky
Stinky
  • 292 posts
Posted 22 June 2015 - 07:24 AM
Haha I didn't see the date weird
#20 Vindi (Russell)
Vindi (Russell)
  • 12,223 posts
Posted 21 February 2016 - 09:43 AM
Just found this thread via a google search ... I just bought a Mk1 MX5 with a zetec conversion so it will be interesting to see how it compares.
On paper ...
1.6 MX5 116 bhp
1.8 MX5 130 bhp
1.8 Zetec 128 bhp
2.0 Zetec 136 bhp
So not much point you'd think. The difference seems to be what happens when you start messing with them.
1.8 MX5 with throttle bodies, nothing else done 150bhp
2.0 Zetec with throttle bodies, nothing else done 165bhp
Add in cams and light head work ...
1.8 MX5 165bhp
2.0 Zetec 200bhp
There's also the option of starting with an ST170 engine which is 172ps out of the box, although the wiring is a bit more complex.
Need to have a think on which way to do this cheaply but it should be an interesting project. I'm not sure it makes much sense to do this if you're starting from scratch, but as someone else has done the hard work it makes it easy for me. The car has been running and driving with a zetec in before so it's all ready to go apart from the engine as the last one blew it's head. So the engine mounts are done, gearbox was changed for an MT75 and a custom prop fitted, all the wiring is done, manifold and exhaust sorted (a real bodge that I'll redo at some point). I just need to slot in an engine (famous last words, it's never that easy).
From memory I might need to adjust the sump, and depending on which Zetec I go for change the water pump as well ...
Russell
