Look What I Made Today :-) - Exterior - MX5Nutz Forum
-1 reply to this topic
#1 OnePaintedMan
OnePaintedMan
  • 3461 posts
Posted 12 February 2011 - 08:14 PM
Well folks this is the first time I've done something like this so I thought I'd share the benefits of a few hours labour in the garage this afternoon (my wife took the kids out so I had some uninterrupted time which is a rarity)!
Decided a while ago to try and emulate the TSI's that Revlimiter created on his car using his walkthrough, so Props to him - his site is an inspiration to me! (Check out Revlimiter.net)
Bought myself the same indicators he purchased (4 for £7.99 delivered from China) and then fr3n2y kindly sold me a spare set of scuzzle motorsport intakes's that he had started to mod (but abandoned and bought some others) for a very cheap price (Cheers fella - hope you like what I've done with them . . ,)! :thumb-up:
So I started my afternoon with this little pile of components
2 x Scuzzle Intake's (One with a hole in)
2 x scooter indicators (only one shown)
2 x push fit plastic pipe reducers (£1.29 each in B&Q - got the last two that weren't ridged inside)
Isopon Plastic bumber filler
and my new favourite plaything. . . my dremel
The beauty of the push fit pipe reducers I discovered are that they are an exact fit and contain and internal rubber ring washer that makes a perfect watertight seal around the indicator once inserted . . .
First I trimmed down a pipe reducer using the dremmel to match the contour of the intake
The amber indicator cover sat inside looks like this. . .
Then I enlarged the hole previously cut in the intake to accomodate the pipe (Testing and fitting was a repetitive process until I was happy with how it sat
Then I attacked it with plenty of filler!
While the filler was drying I turned my attention to the indicator body. I wanted to fit a smaller bulb with a twist fitting rather than risk the fire hazard that would result from the wiring and bulb it came with :trigger:
So I started by cutting the bolt off the indictor body (easy as its mounted into a rubber grommet). I then drilled a hole in the back of the indicator body
There was a third plastic post inside it (for mounting the bulb holder) which I also removed to give more room inside
Then I cut a slot either side of the hole for the push/twist fit bulb holder
The filer was dry bu now so I gave it a good sand down
A couple of test fits and adjustments followed (this photo is of the first fit)
Followed by a good clean and a couple of coats of grey plastic primer. Resulting in this!
Plan to get it sanded down again and then 3 or four layers of topcoat tomorrow (it was too dark to finish up today) Then I can start work on the next one and get them both fitted!
NB: I plan to bond the indicator covers in place and then I will be able to release the rear part (the silver bit) using the two screws that hold the parts together when required to change the bulbs) :thumb-up:
Feeling very pleased with myself - never attempted anything like this before :dance: Never even used filler before! Hope you like my attempt and guide. I promise to get them finished quickly and photo's of the end result up shortly
Project Ronin. For further details check out my build thread.
#2 Adam A
Adam A
    Experiencing life at a rate of several wtf's a minute.
  • 841 posts
Posted 12 February 2011 - 08:18 PM
That looks pretty good chap, well done! :goodjob:
Previous car: MK1 Red 1.6 NA6CE
#3 AndyMk2
AndyMk2
  • Moderators
  • 15498 posts
Posted 12 February 2011 - 08:21 PM
Nice - what are you doing for sidelights?
#4 owldman
owldman
  • 1072 posts
Posted 12 February 2011 - 08:22 PM
looks like you have made a great job of that one hope the other one looks as good well done mate
you must be chuffed with themPosted Image Posted Image
#5 Burd
Burd
  • 149 posts
  • Gender:Female
:worship:
Thats a fantastic job you've done :thumb-up:
Would love to be able to do something like that :drool:
http://Posted Image
#6 Garath
Garath
  • 3355 posts
Posted 12 February 2011 - 08:24 PM
excellent work, and a great write up to, I really like the result :)
#7 OnePaintedMan
OnePaintedMan
  • 3461 posts
Posted 12 February 2011 - 08:26 PM
Thats just what I was sitting here pondering :doh:
Might have to use Leds sat in the intake. . . or maybe get the dremel out again :lol:
Thanks for all the positive comments everyone!
#8 OnePaintedMan
OnePaintedMan
  • 3461 posts
Posted 12 February 2011 - 08:31 PM
Can't decide if I'm going to paint them to match the car or use Satin black. I've got a can of paint in each colour sitting here staring at me
#9 fr3n2y
fr3n2y
  • 3535 posts
Posted 12 February 2011 - 08:41 PM
OMFG I'll have them back bud Ive changed my mind ;)
They look fooking awesome!!!
NOW FOR SALE....
#10 OnePaintedMan
OnePaintedMan
  • 3461 posts
Posted 12 February 2011 - 08:46 PM
:thumb-up: Cheers! I just finished what you started. It was a good hole! :lol:
#11 Tangoman
Tangoman
  • 2750 posts
Posted 12 February 2011 - 08:50 PM
I like the look, very well executed !:thumb-up:
MrT.jpg7ac1c5c3-6188-4314-aa46-a91171da2620_zps
1991 1.6 Asbo Orange T-Spec Eunos Roadster, Orange leather interior, Rota RB's,
1.8 Big brake conversion, MK2.5 5 spead Gearbox, Torsen Type II Differential,
NB Raceland coilovers, Mr Fast front lower brace, OEM Lip spoiler, OBX fuel cap,
Skuzzle Motorsport vented quarter lights, Euro style pressed plates,
NB soft top with heated rear screen, Jass Performance TSI's and instrument fascia.
Performance 5 Chassis rails.
#12 Midnight Racer
Midnight Racer
  • 702 posts
Posted 12 February 2011 - 09:01 PM
Needs more angle towards the middle of the car but the idea is sound! looks like they are pointing a bit spread eagle.
Mad about cars and bikes
#13 OnePaintedMan
OnePaintedMan
  • 3461 posts
Posted 12 February 2011 - 09:35 PM
It is very slightly out to be fair :yes: :doh: - its pretty difficult to get the angle. It looks exaggerated in the photos because the lenses were just pushed in to the rubber seals and haven't been straightened and fixed in place which will help correct the alignment slightly (and the screw holes will be level!)
#14 mx-scott
mx-scott
  • 112 posts
Posted 12 February 2011 - 11:26 PM
They look good although I think I would prefer a clear lens with an orange bulb
#15 dixon206
dixon206
  • 1161 posts
Posted 13 February 2011 - 12:14 AM
That is a fantastic job there fella :goodjob: , you must be very pleased with the finished result.
For the side lights on my TSI's I just used a small amount of mesh and x6 white LED's.
1.8 Mk1 VR-Ltd 1996 (Supercharged)
My Garage
My Project / Build Thread
#16 Francis
Francis
    Less Traction, More Action!
  • 947 posts
Posted 13 February 2011 - 12:41 AM
Best DIY set of TSI's I've ever seen. In fact, they look better made and more OEM than the MX5Parts ones!
#17 revlimiter
revlimiter
    Custom Dial Master
  • Validating
  • 616 posts
Posted 13 February 2011 - 01:01 AM
These look outstanding, Drew! And I think your reducer pipe is an upgrade from my pill bottle. :) I thought I'd post the link and some of my photos here. Don't mean to take away your spotlight though.
Turn Signal Intakes - revlimiter.net
#18 OnePaintedMan
OnePaintedMan
  • 3461 posts
Posted 13 February 2011 - 01:42 AM
[quote name='revlimiter' date='13 February 2011 - 01:01 AM' timestamp='1297558906' post='852118']
Not at all! I'm honoured to have both the pill bottle and Sharka in my thread ^_^ :worship:
Thanks again for showing me the way!
ps: say hi to the Robots. We have a rapidly growing collection here too as my eldest son is obsessed with Transformers!
#19 fr3n2y
fr3n2y
  • 3535 posts
Posted 13 February 2011 - 09:01 AM
For sidelights I've used the headlamp with the sidelight in it.
These..
Just had an MOT and as my pop ups dont come up when the sidelights are on all I did was leave the lights up, and pull the fuse to the motors... :whistle:
Passed fine.
NOW FOR SALE....
#20 SimonBUK
SimonBUK
  • 1161 posts
Posted 13 February 2011 - 09:52 AM
Why did only one of those covers have a indicator in it to start with ?
1990 BBR Turbo - very yellow, very yellow indeed.
Rebuilt entire braking system, Bilstein shocks with RSR springs, Toyo T1S's, rebuilt T25 turbo, rebuilt exhaust manifold, MX5 parts decat with s/s cat back system, alloy radiator, 1.8 flywheel & Excedy clutch, Carbing 6 point roll bar, loads of other stuff i've forgotten as it all got rather expensive.........
1995 1.8 Eunos in Gold Leaf Lotus Racing colours. Very clean, rust free and appears well looked after.
