Fuel Filler Non-Return Valve Thingy?
6 replies to this topic
#1 BCA
BCA
    Ferris Bueller
  • 959 posts
Posted 16 August 2010 - 07:01 PM
Pretty much as title, does anyone have a how to/guide for changing hte fuel filler non return valve? Just back from America and instantly irritated by filling the thing up... I've barely driven my car, so god knows how most of you lot deal with it!?!
As per this link; http://www.miata.net...sb/sb007_99.pdf - it is a known issue and there is a solution, the part number is listed as; GE4T 42 270
I know someone on Pistonheads has had this fitted, but I dont know the costs involved for it/ I'd like to know if it was something I could easily do myself.
Thanks in advance,
Ben CA
#2 BCA
BCA
    Ferris Bueller
  • 959 posts
Posted 19 August 2010 - 03:03 PM
No one has done this then???
#3 AndyMk2
AndyMk2
  • Moderators
  • 15,498 posts
Posted 19 August 2010 - 03:14 PM
It annoyed me as well, you can swap the filler neck for one from a later model and it should be fine.
#4 JQ.
JQ.
  • 1,450 posts
Posted 19 August 2010 - 06:40 PM
It was me who got it sorted on Pistonheads. The part will cost circa 15 from Autolink - it's just a plastic valve, you don't need to replace the whole pipe.
Unfortunately, I did'nt replace it myself, I got Mazda Mender to do it while he was doing various other things on the car. He's on here, and no doubt if you pm him he'll let you know how to do it.
It was by far the best mod I've ever done to the car, I cannot describe how pleasureable my first trip to a petrol station was afterwards, sheer bliss.
#5 Daves
Daves
  • 15 posts
Posted 10 September 2010 - 02:46 PM
I've had the same problem with filling with petrol. Bought a new filter from local mazda dealer (12 or so) and Paul Sheard, Congleton fitted for cost of half an hours labour.
Cured the problem thank god. Used to get quite cold waiting for it to fill in winter !!
#6 BCA
BCA
    Ferris Bueller
  • 959 posts
Posted 13 September 2010 - 10:02 PM
Update, bought the part from Autolink - actually bought the whole bloody filler neck! - 15 all in or something like that... followed mazdamenders guide on PH;
Open fuel filler, remove fuel cap, undo four surrounding bolts.
Open boot, unclip boot carpet bit, remove sheild by the fuel filler.
loosen clips,slide off fuel pipes and remove the fuel filler neck.
Reverse the lot for fitting.
Result - it f'kin works, it took ten mins and cost me 15quid. Bloody ace - thanks to Mazda mender again. Very very glad I did it. Its quicker to fit than it used to be to fill up. :D
#7 AndyMk2
AndyMk2
  • Moderators
  • 15,498 posts
Posted 13 September 2010 - 10:28 PM
Everyone with that era car should do this if not already been done :thumb-up:
