If the standard setup just isn't up to it I was thinking of trying to get hold of a smaller air con radiator from another car, that way the air only has to go through the intercooler to get to the radiotor rather than intercooler, air con rad then radiator. Unless anyone else has some easier tricks?
Cooling + Turbocharging Anyone running + 200bhp + standard rad + air con?
#1
Posted 03 September 2008 - 10:17 PM
#2
Posted 03 September 2008 - 10:43 PM
Ditch the aircon, check you fluid, water pump, I ran 200BHP ok on a standard rad on all but hot days > 200BHP needs an uprated rad IMO.
SMilesMX5 Racing - on event updates Twitter
#4
Posted 04 September 2008 - 07:30 AM
If i decide to push the envelope further I think I'll go for evaporative cooling (water spray) of the intercooler which'll have a secondary effect on the rad.
Reducing the size of the air con condensor coil isn't a good move unless its just marginal, effect when ac is running would be higher condensing temperatures compounding your problem with reduced performance of your ac and increased engine load as a result of increased differential against suction / discharge on the compressor.
#6
Posted 04 September 2008 - 10:46 AM
#7
Posted 04 September 2008 - 10:50 AM
Just because your rad isn't boiling over doesn't mean you don't have a cooling issue.
#8
Posted 04 September 2008 - 11:22 AM
Old car
BMW Z3M Roadster
BBR Turbo.
FM Link ECU, Carbing Cage, Koni's, LC-1 Wideband, Racing Beat ARB's, FM Single Exhaust, De cat, Rota 15'' GT3's, Yoko Prada Spec 2's, 440cc injectors, Custom Intercooler, 11.8 psi boost.
RS Tuning Re-Map. 11.8psi. 228.7bhp 214lb/ft
#9
Posted 04 September 2008 - 11:38 AM
Don't forget EMU has water temp input, fully dataloggable. Can't vouch for the accuracy of the sensor tho.
"Nietzsche is dead" - God, 25 August 1900
2005 Seat Leon FR TDI 150
#10
Posted 04 September 2008 - 12:02 PM
Absolutely. Mine sits at 92/93 deg off boost, but goes over 97 deg C after only about 2 pulls on boost through the gears and i've no AC, a 37mm Koyo rad and a 13 row oil cooler. I've not had my Display for long and have not been on track with it to see what temps it actually reaches however i'd not be suprised it after 15 minutes solid abuse it hit 110deg C ish.
'02 VX220 2.2 n/a - TD Pro Race 1.2's - Chris Tullett 4-1 manifold - Hard Top - AP Racing 295mm brakes & Exige ABS - Pro Alloy Big Rad
'01 VW Passat V6 4motion Estate
#11
Posted 04 September 2008 - 12:13 PM
Trits, on Sep 4 2008, 12:38 PM, said:
Indeed, and sharing NTC thermistors will throw the accuracy out a lot! I never got my EMU to log temp sensors properly.
#12
Posted 04 September 2008 - 12:37 PM
I know from experience that if the engine gets too hot it starts to knock a little. I can vouch for there being no knocking during the last trackday.
#13
Posted 04 September 2008 - 12:46 PM
Trits, on Sep 4 2008, 01:37 PM, said:
When the ECU think's its getting hot surely it pulls timing to prevent knock, so thinking knock = its getting to hot doesn't make sense as the situation shouldn't arise?
#14
Posted 04 September 2008 - 01:53 PM
But it does arise since the factory ecu doesn't know the car is FI'd, by virtue of the piggyback. Therefore the ecu doesn't pull enough timing to prevent knocking, as you say at the higher temperatures the engine probably wouldn't knock if it weren't running boost - but the OP is asking about boosted cars running north of 200 bhp.
Also consider that the early 5s didn't have any form of knock input to the ecu, unfortunately. Back when my water pump failed, I didn't even know I had a problem until the engine began to knock (inaudible). Also, its often been said that the number 2 reason why cylinder 4 suffers greater knock and tends to pop first is because it runs slightly hotter than the other cylinders, due to the heat transfer profile inside the head/block. Hence, even if the ecu did somehow pull timing to prevent knock in cylinders 1 - 3 when in boost, it most likely wouldn't do for cylinder 4.
EDIT: Just remembered, actually I was using the EMU water temp timing adjustment before doing the trackday, so yes in my case you are right more temperature = up to an extra 2 degrees timing retard, which is what I programmed it to pull, iirc. Its driven by the water temp input, but I don't have any reason to believe the temperaure is reading wrong. But, pulling an extra 2 degrees is designed for daily running and won't stop knock if the engine starts to overheat.
MI5 had other problems with his EMU, including hot start issues so I'm guessing its possible there could be a link. Water temp seems okay to me, but I can't get the air intake temp sensor to work right tho...
#15
Posted 04 September 2008 - 03:05 PM
Assuming from the comments above i assume i am pushing my luck!!!
I have seen twin coolers which are great from a packaging point of view, but surely you would be better off with a normal full size alloy rad and a seperate oil cooler rather than the smaller rad you get with a twincooler?
Am i correct about that?
Greg
#16
Posted 04 September 2008 - 03:46 PM
Trits, on Sep 4 2008, 02:53 PM, said:
Thats along the lines i'm thinking, my ECU for example has maps for pulling or adding timing or fueling dependant on temperature from engine core or AIT. As an aside it also drops rev limit and introduces a soft cut followed 300rpm later with hard cut + "cooling off" period at whatever AIT or Engine core temps I set it at.
#17
Posted 04 September 2008 - 06:58 PM
GaryR, on Sep 4 2008, 08:30 AM, said:
I'm not planning on running air con when pushing the car hard on track, I only really use it for demisting. I was hoping to reduce the obstruction in front of the radiator a little. Think I might take the nose cone off at some point to have a look if I can move things around a bit to improve air flow.
#18
Posted 04 September 2008 - 09:42 PM
se how you get on with the Aircon in place, if you get constant problems then consider removing the aircon system, as you say it's only used for demisting anyway I'm sure it won't be missed too much.
My CarDomain Page...
#19
Posted 05 September 2008 - 08:22 AM
Greg
It's hard to say whether or not you're pushing your luck, some cars seem to run hot with boost and some don't. There doesn't even seem to be a common denominator like air con or a standard rad.
With regards to the Twin Cooler I guess there could be a disadvantage due to the fact the rad is slightly smaller rad compared to most uprated ones (still much bigger than stock though). There's also the possibility of heat transfer between the two coolers although my oil and water temps rarely match so I don't think that's a real concern. It's all academic anyway as FM stopped making the twincoolers some time ago.
#20
Posted 05 September 2008 - 11:08 AM
Greg
that's interesting, phil still has them listed on his site, is he just out of date then. As for a temp sensor, where is the best place to site it, i have seen a lot on the top rad hose which is dodgy if you have a leak as the temp will go down rather than up.
Greg
Sign In
Register
Help
MultiQuote
