Remove Air Con Rads And Pump
correctly
9 replies to this topic
#1 C5sat
C5sat
  • 46 posts
Posted 28 September 2012 - 10:01 AM
hi dont use my air con so was wondering if its easy enough to rid it from car
#2 leeglf
leeglf
  • 627 posts
Posted 28 September 2012 - 10:05 AM
its quite an easy job especially if your not planning on keeping the parts, as you can cut the pipes to remove them.
The rad can be easily removed from underneath the car, the only bit i found difficult was removing the pump only because the bolts were so tight, a lot of people don't bother removing the pump but its well worth doing as its very very heavy!
your will need to replace the alternator belt with a shorter one, and will need a heater bypass pipe for behind the glovebox.
Build Thread   : http://www.mx5nutz.c...opic=142485&hl=
Instagram       https://instagram.com/leeglf/
#3 C5sat
C5sat
  • 46 posts
Posted 28 September 2012 - 10:54 AM
thanks for that i thought it might lighten the load
#4 friendly1_uk
friendly1_uk
  • 9,607 posts
Posted 28 September 2012 - 12:02 PM
If it's still working you will need to get it de-gassed before you do anything.
#5 eafy
eafy
  • 6,219 posts
Posted 28 September 2012 - 12:32 PM
Definitely remove the pump as that and the bracket that holds it are really heavy. This is what I took out of mine the other day.
Just don't accidentally drop your power steering fluid like I did :paperbag:.
#6 C5sat
C5sat
  • 46 posts
Posted 28 September 2012 - 12:47 PM
wow yea that looks like a hefty load cheers
#7 friendly1_uk
friendly1_uk
  • 9,607 posts
Posted 28 September 2012 - 01:27 PM
Think I took 15kg off mine. Quite substancial.
#8 eafy
eafy
  • 6,219 posts
Posted 28 September 2012 - 01:49 PM
You can just see the bracket for the pump under the fan and aircon box. It is a great big lump of metal.
The car feels a little freer to rev as well but that is probably just the mod placebo.
#9 AdamR
AdamR
  • 1,563 posts
Posted 28 September 2012 - 02:14 PM
Yeah there's a fair weight there. 28kg for PAS and AC. Try and get a bypass pipe for your heater!
Rattlecanned black Mk1 track hack - 'The Munter': http://www.mx5nutz.c...16681&hl=munter
Grey 2.0 Sport Mk3 daily / track toy: http://www.mx5nutz.c...howtopic=276106
Trackday & race videos: https://www.youtube....hetart20/videos
#10 Efas
Efas
  • 346 posts
Posted 29 September 2012 - 01:15 PM
you need to change not alternator but power steering belt ;) A/C and PS on same belt.
