Getting The Car High
4 replies to this topic
#1 Dazza9t9
Dazza9t9
  • 119 posts
Posted 11 January 2017 - 09:43 PM
Good evening all.
I hope this is the right section, I have just started a turbo build on my mk2.5. I am also considering dropping the rear axle and some other work under the car
The car is currently up on 4 axel stands. It's solid and I am happy working underneath it. However, the stands are not the tallest, and I am certainly not the smallest of chaps
I wonder what other (safe) options I have for getting the car a little higher.
Even another 3 to 4 inches would be great. I have looked at the taller axel stands, I trust they are safe?
Is there any other options I may not know about
#2 Dickie
Dickie
  • 306 posts
Posted 12 January 2017 - 06:56 PM
Hi,
I have got two sets of 4 axle stands, one standard set, OK for working on brakes. and one set of tall axle stands which are 560mm at full height.
If you get a tall set of stands you will need a decent jack to match as most will not lift this high I bought a jack that will lift up to 800mm,
This jack will not go under the car so I use a small trolley jack under the suspension then put the big one under the diff.
The big stands give plenty of height for Gearbox / Clutch changes and pretty much anything else you need to do.
Stands in picture are at 500mm with another 60mm to go
#3 Dickie
Dickie
  • 306 posts
Posted 12 January 2017 - 07:08 PM
Hi again,
Just found another pic of Big Jack in place with normal axle stands with blocks of wood on them.
For the sharp eyed the exhaust system is from a MK 2 and its under a 1994 Eunos 1800, the manifold is from a VVT engine with a modified collector ( To remove the squashed section of pipe at the join )
#4 Dazza9t9
Dazza9t9
  • 119 posts
Posted 12 January 2017 - 11:31 PM
Thanks dickie.
That looks plenty of room. I will get on the look out for some taller axle stands
#5 monka
monka
  • 485 posts
Posted 12 January 2017 - 11:46 PM
Hi again,
Any pics of said modifications to the manifold/collector?
