My First Bike........for Nearly Thirty Years !
35 replies to this topic
#1 crapengineering
crapengineering
  • 395 posts
  • Gender:Female
Posted 30 April 2015 - 06:20 PM
I just bought myself a project bike - a 1985 GSX1100 EFE - a bit of work to do to get it up and running (got it from a breakers , where it went when the electrics went tits up......)
11165859_867524339987746_979599240_n_zps
Its now sitting in my garage , the battery is charging - gonna spend the evening checking over the wiring....... :cry:
Claire .
AKA Clairetoo..............
1990 Eunos , 2.5 KL V6  http://crapengineering.weebly.com/ (YAY !)
#2 Tomyspeedy
Tomyspeedy
  • 42 posts
Posted 30 April 2015 - 06:30 PM
Looks like a lovely bike, so long as the mechanics are all good.
I hope it's all an easy fix for you.
Do you intend on making this a progress thread?
#3 crapengineering
crapengineering
  • 395 posts
  • Gender:Female
Posted 30 April 2015 - 06:35 PM
I've allready found a few corroded / burnt connectors - so shouldnt be too hard to sort . The intention is to get it looking like my last EFE - which got crashed , then turned into a drag bike.........this is it , at just a few weeks old.....
I'll post updates , as and when things happen........!
Claire .
#4 junk yard dog
junk yard dog
  • 5,781 posts
Posted 30 April 2015 - 09:07 PM
you've gone a bought it then  :D
bit of tweaking?  :ph34r:
JOHN 07814 010991
CALLS ONLY NO TEXTS THANKS OR JUST SEND A PM
Posted ImageCRANK LOCKING TOOLS £12 POSTED
mk2/2.5 chassis repair sections £35 each posted
Posted Image Posted Image Posted Image
to see a guide of them being fitted click the link... http://www.mazdamend...php?f=35&t=4102
#5 crapengineering
crapengineering
  • 395 posts
  • Gender:Female
Posted 30 April 2015 - 09:43 PM
A bit of tweaking......but a lot of restoration........everything has been painted , either the wrong colour , or the wrong finish !
Claire .
#6 Ghostrider
Ghostrider
  • 1,642 posts
Posted 30 April 2015 - 10:25 PM
Nice save - too good for the breakers...
#7 h4rri
h4rri
  • 823 posts
Posted 01 May 2015 - 07:11 AM
Nice bike :)
Just a suggestion but consider doing a CBT or other training day before you hop back on. My Dad bought a bike after a number of years off one and nearly wiped out several times as he just wasn't used to being on the road on a bike etc :(
#8 crapengineering
crapengineering
  • 395 posts
  • Gender:Female
Posted 02 May 2015 - 02:01 PM
Well , a couple of hours sorting the wiring (needs a new regulater/rectifier) , fresh plugs , and it fired right up - smoked a little , no nasty rattles , and sounds proper !
Took it for a quick run up the road and back - feels fantastic apart from a seized rear calliper , its got all its gears and pulls like a train :whistle:
Claire .
#9 stuartb
stuartb
  • 4,026 posts
Posted 03 May 2015 - 11:32 PM
I keep looking at 1973 (or earlier) bikes on ebay with a view to buying one.  The 1980s bikes put me off due to the square-looking lights, and the Back-to-the-Future styling.
Either way, it's nice to see an old bike get restored and back onto the road.  I'm sue that you only need a few hours of slow-speed manoeuvring before you're back up to speed.
#10 junk yard dog
junk yard dog
  • 5,781 posts
Posted 05 May 2015 - 09:05 PM
Either way, it's nice to see an old bike get restored and back onto the road.  I'm sue that you only need a few minutes of slow-speed manoeuvring before you're back up to speed.
edited for accuracy  :whistle:
JOHN 07814 010991
#11 crapengineering
crapengineering
  • 395 posts
  • Gender:Female
Posted 14 June 2015 - 08:21 AM
Well , I fitted a new regulator / rectifier to sort the charging......and still nothing . So then I swapped the generator windings - and bingo , sorted .
Except - when I pulled the genny cover , out poured a very thin petrol / oil mix.......like about 6 liters of it ! Vacuum fuel taps are great , when they work........so out with the oil filter , and off with the oil cooler lines - more of the same .
With fresh oil and filter in , an earth fault of the rear lights fixed - it was in for an MOT......and it passed with just one advisory - `loud exhaust' :dance:
I wrapped the baffle with the only thing I had - exhaust wrap , which has made a huge difference.
And since then - about 3 weeks ago - I have just been riding it.......a lot :thumb-up2:
Picked these up at the weekend........
GSXR600 wheels , complete with tires and discs - just £110 :D
Let the `improvements' begin :rolleyes:
Claire .
#12 PaddyShepherd
PaddyShepherd
  • 592 posts
Posted 25 June 2015 - 12:27 PM
Nice bike. Suzuki's are generally pretty nice to work on. Clever too - I did a fork rebuild on my bandit, there's essentially a 24mm socket inside the fork that needs gripping to be able to undo the damper screw; after several hours of hunting around for something that would work we had a light bulb moment. The rear axle nut and bolt were 24mm A/F and long enough to put inside the fork! Good luck :)
#13 atlex
atlex
  • 1,199 posts
Posted 25 June 2015 - 03:07 PM
Lovely looking bike :-)
Blue NA G19/ME221 td04. White NA RS-Aizawa ITB/8K RPM. And stuff.
#14 crapengineering
crapengineering
  • 395 posts
  • Gender:Female
Posted 02 September 2015 - 10:26 PM
......still riding it , still loving it , and still collecting parts for a good solid winter rebuild session :whistle:
I had been looking around for various parts - my fork legs are horribly pitted , its missing the rear section of the rear mudguard , and just about everything needs a proper re-paint or powder coat .
So........I just bought a failed restoration project off ebay , which has just about all the parts mine is missing - plus all the work has been done as far as paint and powdercoat goes .
It came home in the back of my Corsa......
  • 1
Claire .
#15 unclepoo
unclepoo
  • 343 posts
Posted 03 September 2015 - 06:14 PM
If you`re feeling brave, try fitting gsxr1000 suspension front and back...lots of lads on the bandit forum have done this and can help with technical advice. My 1200 bandit has this suspension and rides much better than standard.
I think gsxr head and cams can be fitted too, to give you more top end bhp.
#16 crapengineering
crapengineering
  • 395 posts
  • Gender:Female
Posted 20 September 2015 - 04:47 PM
I'm not planning on a suspension swap - and since I could easily get more power from the stock head than I could ever use on the road , that will be staying too .
I've had a busy week in the shed , measuring and machining , and it now has the Gsx600 Srad wheels fitted , with floating EBC discs , Zxr750 six pot calipers , and nice new tyres....... Just took it out for a 30 mile test run , and it feels so much better now !
Claire .
#17 crapengineering
crapengineering
  • 395 posts
  • Gender:Female
Posted 01 October 2015 - 08:45 PM
I just did a little mod to the rear suspesion linkage , which has raised the back about 1 1/2 inch's.........damn its looking good now :drool:
Claire .
#18 lewis87
lewis87
  • 351 posts
Posted 02 October 2015 - 02:04 PM
Older bikes can look a bit low at the back, looks much better with a bit of "rake"
GSXR wheels look great too.
#19 Tron
Tron
  • 383 posts
Posted 10 November 2015 - 08:26 PM
will keep my eye on this i need inspiration for my bandit, getting more and more into the retro muscle bikes all the time.
32 year old apprentice wasting my money on MK1 1800 Eunos-ZZR1100C-Bandit1200
#20 crapengineering
crapengineering
  • 395 posts
  • Gender:Female
Posted 03 January 2016 - 04:45 PM
Been a bit quiet about this for too long......mainly because I've been too busy riding it to do much else :whistle:
I did get around to changing the `bars - I was never a fan of the fork-top clipons , so a pair of cheap eblag mounts were found , the correct (for the model) clutch lever bracket fitted , and a better master cylinder to suitthe six pots went on .
Fast forward to something resembling winter , and I finally got round to working on the motor properly . It had been drinking oil since I got it , 150 miles from a litre was a bit much , so out came the spanners . It did have the normal clutch rattle , but the basket is mint......?
It does however show some nasty wear on the primary drive gear , so a fresh basket is now on the shopping list (cheaper than a heavy duty backplate , which was what was planned)
The cams , however , are toast........ While the lobes and rockers are spot on , there is serious wear on most of the bearings.....so fresh cams are now being sought.....
I pulled the rest of the motor (with a lift from junkyard dog , damn thing is too heavy for me :thumb-up2: ) , the bores are too worn for just new rings so a bit of a re-think on what to do there is going on......dont want a monster big bore motor , but that seems to be all that is available.......
I've sourced new stock rings from the states , and I do have an early block that has been bored with EFE pistons - if I can re-shape the fins to match the EFE ones , that may well save me a lot of money , and keep it stockish......
Claire .
